I use the Arduino MKR WAN 1310 to send messages to The Things Stack. All the examples of the MKRWAN.h are referring only to sending strings. This works fine. I’d like to send a byte though, so I changed the code slightly.
// Define an array with a byte
uint8_t msg[1];
byte var = 143;
msg[0] = var;
// Send the the message
int err;
modem.beginPacket();
modem.print(msg[0]);
err = modem.endPacket(true);
// Check if the message has been sent correctly
if (err > 0) {
Serial.println("Message sent correctly!");
Serial.println("Error sending message :(");
The message is being sent correctly to the TTS, but as it seems as a string. In TTS the string formater gives me the correct result of “143” as a string.
function Decoder(bytes, port) {
var result = "";
for (var i = 0; i < bytes.length; i++) {
result += String.fromCharCode(parseInt(bytes[i]));
return { payload: result, };
A formater for bytes gives me not a result of 143 but of 49.
var decoded_var = bytes[0];
return {
var: decoded_var
Is the MKRWAN.h designed only to send strings to the TTS?
