MKRWAN1310+LoRa Library
I want to send messages with the LoRa frequency and protokoll without all the TTN stuff.
I try to use the LoRa Lib with the MKRWAN1310. Everythings seems fine, the EndPackage() returns 1, witch means success.
When I watch the frequency with my HackRF radio receiver, no signal goes out.
I suspect, that the default PINS are wrong. Witch are the SS, RESET and DIo0 Pins at the MKRWAN1310?
Has someone experience with this combination?
#include <SPI.h>
#include <LoRa.h>
String message;
int counter = 0;
int err;
  Serial.println("LoRa message service");
  LoRa.setFrequency(867400000);
  LoRa.setSpreadingFactor(7);
  LoRa.setSignalBandwidth(100000);
   if (!LoRa.begin(868E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
  Serial.println("Starting LoRa !");
  message = "hello world from me ";
  if (message.length() > 0)
    Serial.print("Me("); Serial.print(counter);
    Serial.print("): " + message);
    LoRa.beginPacket();
    LoRa.print(message);
    err = LoRa.endPacket(1);
    message = "";
    counter++;
    Serial.print(" err="); Serial.print(err);  // 1= success
You would need to check the LoRa library documentation, its supposed to support the MKRWAN1300, not sure if the 1310 is different.
100000 is not a valid bandwidth for LoRa.
