MKRZero as USB host device, possible?
Hello,
I would like to use MKRZero as a USB host.
According to the regular Zero documentation, Zero can be a USB host device, but it is not clear if the MKRZero can do the same, as there is only one USB port. Can anyone please verify this point?
www.arduino.cc/en/Guide/ArduinoZero
The Zero has two USB ports available. --
Using the Native port enables you to use the Zero as a client USB peripheral (acting as a mouse or a keyboard connected to the computer) or as a USB host device so that devices can be connected to the Zero (like a mouse, keyboard, or an Android phone).
Hi @NT_N
Yes, this is possible with a USB OTG cable, however you'll need to power the MKRZero using Vin.
The following library which is bundled with the SAMD core you have installed: ArduinoCore-samd/libraries/USBHost at master · arduino/ArduinoCore-samd · GitHub
Hi sandeepmistry
Thanks for your fast response!
I forgot about needing an otg cable, so good call!
Have you used the MKRZero? How do you like it?
@NT_N
Sandeep is your GOTO MKR GURU...Along with Martino.
You will come to appreciate his knowledge if you look him up deeper (no stalking tho LOL)
