MKRZERO extra serial ports
Hi, I followed the official arduino tutorial to create an extra UART TX/RX port and for my MKRzero and modified it slightly to produce:
  AnalogReadSerial on new UART placed on pins 1 and 0
  Reads an analog input on pin A0, prints the result to the serial monitor.
  Graphical representation is available using serial plotter (Tools > Serial Plotter menu)
  Attach the center pin of a potentiometer to pin A0, and the outside pins to +3.3V and ground.
  Short together pin 1 and pin 0 with a wire jumper
 Created 20 Jun 2016
 by
 Arturo Guadalupi <a.guadalupi@arduino.cc>
  This example code is in the public domain.
#include <Arduino.h>
#include "wiring_private.h"
Uart mySerial (&sercom3, 1, 0, SERCOM_RX_PAD_1, UART_TX_PAD_0); // Create the new UART instance assigning it to pin 1 and 0
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
  mySerial.begin(9600);
  pinPeripheral(1, PIO_SERCOM); //Assign RX function to pin 1
  pinPeripheral(0, PIO_SERCOM); //Assign TX function to pin 0
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  int sensorValue = analogRead(A0);
  // print out the value you read on mySerial wired in loopback:
  mySerial.write(sensorValue);
  while (mySerial.available()) {
    Serial.print(mySerial.read());
  delay(1);        // delay in between reads for stability
// Attach the interrupt handler to the SERCOM
void SERCOM3_Handler()
  mySerial.IrqHandler();
I am using an Analog Discovery 2 to try and read the serial values coming off the arduino and am stumped. It does not seem to be outputting anything?
I have the digital pin 0 connected to arduino pin 0, and I also tried to connect GND of the analog discovery 2 to the arduino GND with no luck.
Any ideas what I am doing wrong? Any other ideas for debugging this serial method?
