Hi everyone there,
i am working on Stepper motor which is driven by MKS Gen 1.4 Board (its Arduino Mega chip) and graphical display
My code is bit bulky and having unnecessary stuff as well, as i have make it with the help of various codes available on internet.
however its working as required till the date but now after putting optocoupler for inputs.
for inputs i have Optical diffusion type sensor
all the button mention in code are above device only, following is the issue i am facing with this code compare to earlier.
- earlier the Output change as soon as input get change but now output change only if input change and again back to initial stage. (here output is used to drive steppers motors)
one issue having since starting as below.
- every time its updating to text file instead of taking directly refence from the text file stored in SD Card. its note there in void loop but still its updating at each cycle
//Display library
#include <GEM_u8g2.h>
U8G2_ST7920_128X64_1_SW_SPI u8g2(U8G2_R0, 23 , 17, 16 );
// SD Library
#include <SPI.h>
#include <SD.h>
//Keypad
#define B1 40
#define B2 44
#define B3 59
#define B4 63
#define B5 42
#define B6 65
#define MOSI 51
#define MISO 50
#define CLK 66
#define CS 53
File myFile;
//Steppers
//stepper-1
#define EN1 38
#define X_DIR 55
#define X_STP 54
const int buttonPin1 = 2;
int buttonState1 = 0;
//stepper-2
#define EN2 56
#define Y_DIR 61
#define Y_STP 60
const int buttonPin2 = 3;
int buttonState2 = 0;
const int buttonPin3 = 14;
int buttonState3 = 0;
// Create variables that will be editable through the menu and assign them initial values
int Length1 = 0;
int Speed1 = 0;
int Length2 = 0;
int Speed2 = 0;
int Delay1 = 0;
int Delay2 = 0;
int Rot1 = 0;
int Rot2 = 0;
boolean CW = false;
//boolean Clock2 = false;
//M1 motor setting
GEMItem menuItemIntervalM1("Length:", Length1);
GEMItem menuItemSpeedM1("Speed:", Speed1);
GEMItem menuItemDelayM1("Delay:", Delay1);
GEMItem menuItemRotM1("Rotation:", Rot1);
//GEMItem menuItemBool("Rotatioin:", CW);
//M2 motor setting
GEMItem menuItemIntervalM2("Length:", Length2);
GEMItem menuItemSpeedM2("Speed:", Speed2);
GEMItem menuItemDelayM2("Delay:", Delay2);
GEMItem menuItemRotM2("Rotation:", Rot2);
//GEMItem menuItemBool("Rotatioin:", Clock2);
// Motor steps codes
void step(boolean dir, byte dirPin, byte stepperPin, int steps, int delayTime)
digitalWrite(dirPin, dir);
delay(100);
for (int i = 0; i < steps; i++)
digitalWrite(stepperPin, HIGH);
delayMicroseconds(delayTime);
digitalWrite(stepperPin, LOW);
// Main Menu List
GEMPage menuPageMain("Select Motor"); // Main page
GEMPage menuPageM1("M1"); // Settings submenu
GEMPage menuPageM2("M2");
// Create menu item linked to Settings menu page
GEMItem menuItemMainM1("M1", menuPageM1);
GEMItem menuItemMainM2("M2", menuPageM2);
// Create menu object of class GEM_u8g2. Supply its constructor with reference to u8g2 object we created earlier
GEM_u8g2 menu(u8g2);
// one time runing items in setup menu
Serial.println("Initializing SD card... ");
if (!SD.begin(53)) {
Serial.println("Card initialization failed!");
while (true);
Serial.println("Card Initialization Success.....");
Length1 = readFile("Length1.txt"); //read full content of file
Speed1 = readFile("Speed1.txt"); //read full content of file
Delay1 = readFile("Delay1.txt"); //read full content of file
Rot1 = readFile("Rot1.txt"); //read full content of file
Length2 = readFile("Length2.txt"); //read full content of file
Speed2 = readFile("Speed2.txt"); //read full content of file
Delay2 = readFile("Delay2.txt"); //read full content of file
Rot2 = readFile("Rot2.txt"); //read full content of file
//M1 pin define
pinMode(buttonPin1, INPUT);
pinMode(X_DIR, OUTPUT); pinMode(X_STP, OUTPUT);
pinMode(EN1, OUTPUT);
digitalWrite(EN1, LOW);
//M2 Pin define
pinMode(buttonPin2, INPUT);
pinMode(Y_DIR, OUTPUT); pinMode(Y_STP, OUTPUT);
pinMode(EN2, OUTPUT);
digitalWrite(EN2, LOW);
// limit switch
pinMode(buttonPin3, INPUT);
//Keypad
pinMode(B1, INPUT);
pinMode(B2, INPUT);
pinMode(B3, INPUT);
pinMode(B4, INPUT);
pinMode(B5, INPUT);
pinMode(B6, INPUT);
//u8g2.begin(/*Select/OK=*/ 35, /*Right/Next=*/ 31, /*Left/Prev=*/ 15, /*Up=*/ U8X8_PIN_NONE, /*Down=*/ 33, /*Home/Cancel=*/ 18); // without Remote
u8g2.begin(/*Select/OK=*/ B1, /*Right/Next=*/ B2, /*Left/Prev=*/ B3, /*Up=*/ B4, /*Down=*/ B5, /*Home/Cancel=*/ B6); //with Remote
// Menu init, setup and draw
menu.init();
setupMenu();
menu.drawMenu();
void setupMenu() {
// Add menu items to Settings menu page
menuPageM1.addMenuItem(menuItemIntervalM1);
menuPageM1.addMenuItem(menuItemSpeedM1);
menuPageM1.addMenuItem(menuItemDelayM1);
menuPageM1.addMenuItem(menuItemRotM1);
menuPageM2.addMenuItem(menuItemIntervalM2);
menuPageM2.addMenuItem(menuItemSpeedM2);
menuPageM2.addMenuItem(menuItemDelayM2);
menuPageM2.addMenuItem(menuItemRotM2);
// Add menu items to Main Menu page
menuPageMain.addMenuItem(menuItemMainM1);
menuPageMain.addMenuItem(menuItemMainM2);
// Specify parent menu page for the Settings menu page
menuPageM1.setParentMenuPage(menuPageMain);
menuPageM2.setParentMenuPage(menuPageMain);
// Add Main Menu page to menu and set it as current
menu.setMenuPageCurrent(menuPageMain);
int steps1;
int steps2;
int delTime1;
int delTime2;
int DelayTime1;
int DelayTime2;
int RotTime1;
int RotTime2;
// If menu is ready to accept button press...
if (menu.readyForKey())
// ...detect key press using U8g2 library and pass pressed button to menu
menu.registerKeyPress(u8g2.getMenuEvent());
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
buttonState3 = digitalRead(buttonPin3);
if (buttonState1 == LOW) {
delay (10);
if (buttonState1 == LOW && buttonState2 == HIGH && buttonState3 == LOW) {
if (steps1 != Length1) {
steps1 = validateIntervalM1();
else {
steps1 = Length1;
if (delTime1 != Speed1) {
delTime1 = validateSpeedM1();
else {
delTime1 = Speed1;
if (RotTime1 != Rot1) {
RotTime1 = validateRotM1();
else {
RotTime1 = Rot1;
if (RotTime1 == 1) {
step(true, X_DIR, X_STP, steps1, delTime1);
// Serial.println("Rotate Clockwise... ");
else {
if (RotTime1 == 0) {
step(true, -X_DIR, X_STP, steps1, delTime1);
//Serial.println("Rotate Anti Clockwise... ");
if (DelayTime1 != Delay1) {
DelayTime1 = validateDelayM1();
else {
DelayTime1 = Delay1;
delay(DelayTime1);
else if (buttonState1 == LOW && buttonState2 == LOW && buttonState3 == LOW) {
if (steps2 != Length2) {
steps2 = validateIntervalM2();
else {
steps2 = Length2;
if (delTime2 != Speed2) {
delTime2 = validateSpeedM2();
else {
delTime2 = Speed2;
if (RotTime2 != Rot2) {
RotTime2 = validateRotM2();
else {
RotTime2 = Rot2;
if (RotTime2 == 1) {
step(true, Y_DIR, Y_STP, steps2, delTime2);
else {
if (RotTime2 == 0) {
step(true, -Y_DIR, Y_STP, steps2, delTime2);
if (DelayTime2 != Delay2) {
DelayTime2 = validateDelayM2();
else {
DelayTime2 = Delay2;
delay(DelayTime2);
//Validation routine of interval variable
int validateIntervalM1() {
if (Length1 < 00) {
Length1 = 0;
Serial.print("Interval set: ");
Serial.println(Length1);
writeFile("Length1.txt", Length1);
return Length1;
int validateSpeedM1() {
if (Speed1 < 0) {
Speed1 = 0;
Serial.println(Speed1);
writeFile("Speed1.txt", Speed1);
return Speed1;
int validateDelayM1() {
if (Delay1 < 0) {
Delay1 = 0;
Serial.println(Delay1);
writeFile("Delay1.txt", Delay1);
return Delay1;
int validateIntervalM2() {
if (Length2 < 0) {
Length2 = 0;
Serial.println(Length2);
writeFile("Length2.txt", Length2);
return Length2;
int validateSpeedM2() {
if (Speed2 < 0) {
Speed2 = 0;
Serial.println(Speed2);
writeFile("Speed2.txt", Speed2);
return Speed2;
int validateDelayM2() {
if (Delay2 < 0) {
Delay2 = 0;
Serial.println(Delay2);
writeFile("Delay2.txt", Delay2);
return Delay2;
int validateRotM1() {
if (Rot1 < 0) {
Rot1 = 0;
Serial.print("Rot1 : ");
Serial.println(Rot1);
writeFile("Rot1.txt", Rot1);
return Rot1;
int validateRotM2() {
if (Rot2 < 0) {
Rot2 = 0;
Serial.print("Rot2 : ");
Serial.println(Rot2);
writeFile("Rot2.txt", Rot2);
return Rot2;
int readFile(String fileName) {
myFile = SD.open(fileName);
if (myFile) {
// read from the file until there's nothing else in it:
String received = "";
char ch;
while (myFile.available()) {
ch = myFile.read();
if (ch == '\n')
received += ch;
myFile.close();
return received.toInt();
// if the file didn't open, print an error:
Serial.println("error opening file...");
void writeFile(String FileName, int NewValue) {
SD.remove(FileName);
myFile = SD.open(FileName, FILE_WRITE);
if (myFile) {
myFile.println(NewValue);
myFile.close();
Serial.println("File update successfully...");
Serial.println("error opening in " + FileName);
if someone can guide me to resolve this issue then it will be great help to me, i have already damage one MKS gen board, display, optical sensors and many more devices for trial and error.
thanks in advance for your valuable time
