Nead help with mks robin nano v3.1 as there is no boards and outher gonfig files oand egzamples that can gide me to make a scetch and upload it to this board .The mcu is STM32F407VET6 .firmware.bin nano_v3_bootloader.bin Robin_nano_v3.bin installed via flash card. CH341SER driver installwd windows 10 . Mks GEN L was no problem and works fine . I am intending to use the RepRapDiscount 20X4 Smart Controller or or the RepRapDiscount Full Graphic Smart Controller
HI @theidd. Your post is incomprehensible. Please add a reply here on this forum thread with a clear and detailed description. Take the time to carefully proof read your post and correct all typos before publishing it.
OP probably has a MKS Robin Nano V3 board which is a 32-bit 3D printer control board based on the Arm Cortex-M4 STM32F407VGT6
➜ Home · makerbase-mks/MKS-Robin-Nano-V3.X Wiki · GitHub
it does not seem to relate to IDE 1.x category... (and I don't know what OP really wants to do)
Mks robin nano v3.1 MISING files not found in the arduino ide for this board . No demmo files for one to learn frm
Marlin2.0 will not uploud
Based on the vague description you have provided, the only advice I can give you is to carefully read all the information at the link provided by @J-M-L in post #3.
If you want more assistance from us, then you are going to have to make a stronger effort at communicating. We are here to help, but we are not psychic. The only information we have about your situation is what you write here on the forum. If you don't write much, and don't write clearly, then we don't know much about your situation and thus aren't able to provide much assistance.
I don't think you install the firmware using the Arduino's IDE hence there is no board definition for your MKS... double check the manual..
Firmware upload wia SD CARD dun no displaqy.Hardware =MKS Robin Nano V.1 + LCD display with SD card reader for RAMPS 1.4 OR Smart LCD Graphical display with SD card reader for RAMPS 1.4 .HOW TO CONFIGER PROGAM FOR A 3D PRINTER WITH THIS HARDWARE ?
S ETUO FROM LINK Mks robin nano v3.1 - #3 by J-M-L IS FOR ```
MKS Robin Nano V3 + MKS TS35 touch Screen
MINE IS
1; MKS Robin Nano V3 + LCD display with SD card reader for RAMPS 1.4
2: MKS Robin Nano V3 + Smart LCD Graphical display with SD card reader for RAMPS 1.4
MKS Robin Nano V3.1 – 3D Printing Store LISTS IT AS MKS Robin Nano V3.1 + LCD Supported: MKS TS35 / MKS H45 / LCD12864 / LCD2004
find the relevant documentation. It's possible that you don't configure it through the IDE but possibly by installing the firmware on an SD card and using the system to load the firmware directly on your unit.
How to ad thease boarde to the ardoino ide
marlin_STM32F407VET6_CCM.json (1.2 KB)
marlin_STM32F407VGT6_CCM.json (1.2 KB)
marlin_STM32F407ZGT6.json (1.3 KB)
marlin_STM32F429VGT6.json (1.0 KB)
Follow the instructions here:
https://github.com/stm32duino/Arduino_Core_STM32#getting-started
Thank you
You are welcome. I'm glad if I was able to be of assistance.
Regards, Per
Got 2 bowdrs .1 loards fine shows full graficas The other 0ne fales grafixs .Bouth identicle shoftware . Was told by 3D PrintShop in bloxburg that the GRAFIC CHIP was falty. Did resrch online and the chip they showed me as falty is acteuly a EPROM CHIP U3 W25Q64JVSSIQ
