So I following the instructions of this URL https://www.arduino.cc/en/Tutorial/SimpleAudioPlayerZero to connect the circuit with the MKZero board. However, when I put the codes(also in this URL), the IDE says error for the board.
Here is the code:
Simple Audio Player for Arduino Zero
Demonstrates the use of the Audio library for the Arduino Zero
Hardware required :
- Arduino shield with a SD card on CS4
- A sound file named "test.wav" in the root directory of the SD card
- An audio amplifier to connect to the DAC0 and ground
- A speaker to connect to the audio amplifier
Arturo Guadalupi a.guadalupi@arduino.cc
Angelo Scialabba a.scialabba@arduino.cc
Claudio Indellicati c.indellicati@arduino.cc
This example code is in the public domain
#include <SD.h>
#include <SPI.h>
#include <AudioZero.h>
// debug output at 115200 baud
// setup SD-card
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println(" failed!");
while(true);
Serial.println(" done.");
// 44100kHz stereo => 88200 sample rate
AudioZero.begin(2*44100);
int count = 0;
// open wave file from sdcard
File myFile = SD.open("test.wav");
if (!myFile) {
// if the file didn't open, print an error and stop
Serial.println("error opening test.wav");
while (true);
Serial.print("Playing");
// until the file is not finished
AudioZero.play(myFile);
Serial.println("End of file. Thank you for listening!");
while (true) ;
The error message: : fatal error: AudioZero.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board Arduino MKRZero.
Could someone help me fix it, thanks!
