okay. thank you
the sensor show me values in mw/cm²
do you know if i can calculate it to the UV-Index???
i found a duv-factor 1.61 but i don't know if ít is correct.
This gives us an Erythema corrected irradiance figure of 0.0916 W/m2. The UV Index itself is an irradiance scale calculated by multiplying the Erythema corrected irradiance in watts per m2 by 40. This gives us a UV index figure for the sample of 0.0916 x 40 = 3.66.
at this moment i get a outputVoltage from the A0 oin about 1.09, but it's night. Fully dark outside...
but i knwo, that the wemos d1 has a constant A0 reading volt, without any sensors too.
on a other wemos i have always around ~2.25mV. So maybe this is the reason, for the postivie value although it is dark
