MLX+PID Library
i tried to use the PID library together with the MLX temperature sensor (SDA/SCL)
program compiles and uploads but nothing happens.
cant figure it out. does the PID lib only work with Analog input?
please review someone thanks! :slight_smile:
#include <PID_v1.h>
#include <Wire.h>
#include <Adafruit_MLX90614.h>
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
#define RELAY_PIN 12
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
double Kp=2, Ki=5, Kd=1;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
int WindowSize = 5000;
int temp = mlx.readObjectTempC();
unsigned long windowStartTime;
Serial.println("Adafruit MLX90614 test");
mlx.begin();
  windowStartTime = millis();
  //initialize the variables we're linked to
  Setpoint = 100;
  //tell the PID to range between 0 and the full window size
  myPID.SetOutputLimits(0, WindowSize);
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
Serial.print("*C\tObject = "); Serial.print(mlx.readObjectTempC()); Serial.println("*C");
delay(50);
  Input = temp;
  myPID.Compute();
   * turn the output pin on/off based on pid output
  if (millis() - windowStartTime > WindowSize)
  { //time to shift the Relay Window
    windowStartTime += WindowSize;
  if (Output < millis() - windowStartTime) digitalWrite(RELAY_PIN, HIGH);
  else digitalWrite(RELAY_PIN, LOW);
note that PID_v1 has a fixed DeltaT
bool PID::Compute()
   if(!inAuto) return false;
   unsigned long now = millis();
   unsigned long timeChange = (now - lastTime);
   if(timeChange>=SampleTime)
///... PID Calculation
      return ture;
so doing something like
// ... In the setup() add:
    myPID.SetSampleTime(50); // PID loop will only be true every 50 ms Rather than unsin delay(50); in your loop
  temp = mlx.readObjectTempC(); //<<< missing in the loop <<< don't forget to get your temperature again
  Input = temp;
  if(myPID.Compute()){
Z
