mlx906 i2c help
Here : I have connected 4 MLX90614 temp sensors which work on i2c protocol I have got the code worked out but, I am facing some weird problem the problem is:
Initially the program runs well but if I power off the arduino and repower it the data gets hanged and the results are:
Setup...
> Read address
  MLX address: 0, Data: Setup...
> Read address
It gets stuck here and doesnot proceed... BUT, I interchanged as follows:
A4--->SDA A5--->SCL (initial connections)
changed to:
A4--->SCL A5----->SDA resetted the controller and then back to:
A4--->SDA A5--->SCL and started to work back I tried it more than 5 times the same thing I needed to do.
Now how do I resolve this issue???
here is my code:
#include "i2cmaster.h"
float ReadTemp(byte);
  Serial.println("Setup...");/**/
  // Initialise the i2c bus, enable pullups and then wait
  i2c_init();
  PORTC = (1 << PORTC4) | (1 << PORTC5);
  delay(5000);
  // Read current address bytes
  ReadAddr(0);
  Serial.println("**---DONE---**");
 ReadTemp(0X0D);
  delay(2000);
   ReadTemp(0X0A);
delay(2000);
     ReadTemp(0X0C);
  delay(2000);
     ReadTemp(0X0B);
  delay(2000);
float ReadTemp(byte address) {
  int data_low = 0;
  int data_high = 0;
  int pec = 0;
  byte MLXAddress = address<<1;
  Serial.print("> [ReadTemp] Read temperature ");
  if (MLXAddress == 0) {
    Serial.print("using MLX univeral address");
    Serial.print("using MLX address ");
    Serial.print(address, HEX);
  Serial.print(": ");
  i2c_start_wait(MLXAddress + I2C_WRITE);
  i2c_write(0x07);
  i2c_rep_start(MLXAddress + I2C_READ);
  data_low = i2c_readAck();
  data_high = i2c_readAck();
  pec = i2c_readNak();
  i2c_stop();
  float temp = 0x0000;
  temp = (float)(((data_high & 0x007F) << 8) + data_low);
  temp = (temp * 0.02) - 273.16;
  Serial.print(temp);
  Serial.println(" C");
  return temp;
void ReadAddr(byte Address) {
  Serial.println("> Read address");
  // Inform the user
  Serial.print("  MLX address: ");
  Serial.print(Address, HEX);
  Serial.print(", Data: ");
  // Send start condition and write bit
  i2c_start_wait(Address + I2C_WRITE);
  // Send command for device to return address
  i2c_write(0x2E);
  i2c_rep_start(Address + I2C_READ);
  // Read 1 byte and then send ack (x2)
  Serial.print(i2c_readAck(), HEX);
  Serial.print(", ");
  Serial.print(", ");
  Serial.println(i2c_readNak(), HEX);
  i2c_stop();
the output I got was :
Setup...
> Read address
> Read address
> Read address
  MLX address: 0, Data: 8, 0, 80
**---DONE---**
> [ReadTemp] Read temperature using MLX address D: 30.46 C
> [ReadTemp] Read temperature using MLX address A: 26.98 C
> [ReadTemp] Read temperature using MLX address C: 26.02 C
> [ReadTemp] Read temperature using MLX address B: 26.10 C
> [ReadTemp] Read temperature using MLX address D: 27.40 C
> [ReadTemp] Read temperature using MLX address A: 27.10 C
I miss the link to that i2cmaster library.
Why don't you use the Wire library?
