MLX90614 Sensor Detection Issue with Arduino UNO R4 WiFi
Hello everyone,
I'm having trouble connecting my MLX90614 temperature sensor to my Arduino UNO R4 WiFi. Despite my efforts, the sensor is not being detected by the Arduino. I've checked the connections and the code, but I can't seem to figure out the issue.
Could anyone help me understand what might be causing this problem or suggest some ways to fix it?
Thank you very much for your help!
Can you also take a picture of the circuit? (just to double-check) Can you also send the code?
Your topic does not indicate a problem with the Arduino Command Line Tools and therefore has been moved to a more suitable location on the forum.
I have no experience with the MLX90614, but the MLX90640.
  1. Check the datasheet:
I think you need to apply level shifter or voltage divider for SDA, SCL.
  1. From the photo it looks like there is no I2C pull-up resistor. Try pulling up SDA and SCL with a few KΩ to 10 KΩ.
  2. The maximum frequency for Uno R4 I2C is 400KHz. Try lowering it to 100KHz.
Edit: Please use the <code> tag to post your code instead of the screenshot. The code is hard to read in the picture, can't be quoted, and can't be copied and pasted to test.
And my failure story:
thank you very much ,
I will try that .
