Would like to use this well written, comprehensive MLX90614_Serial_Demo code with a SAMD21.
Code works perfect with an UNO but I cannot compile when selecting the SAMD board in the IDE.
I think this is an easy fix and has something to do with the different architectures but not being a C programmer I cannot correct the code.
Any help would be appreciated.
Ken
#include <Wire.h> // I2C library, required for MLX90614
#include <SparkFunMLX90614.h> // SparkFunMLX90614 Arduino library
IRTherm therm; // Create an IRTherm object to interact with throughout
const byte LED_PIN = 8; // Optional LED attached to pin 8 (active low)
Serial.begin(9600); // Initialize Serial to log output
therm.begin(); // Initialize thermal IR sensor
therm.setUnit(TEMP_F); // Set the library's units to Farenheit
// Alternatively, TEMP_F can be replaced with TEMP_C for Celsius or
// TEMP_K for Kelvin.
pinMode(LED_PIN, OUTPUT); // LED pin as output
setLED(LOW); // LED OFF
setLED(HIGH); //LED on
// Call therm.read() to read object and ambient temperatures from the sensor.
if (therm.read()) // On success, read() will return 1, on fail 0.
// Use the object() and ambient() functions to grab the object and ambient
// temperatures.
// They'll be floats, calculated out to the unit you set with setUnit().
Serial.print("Object: " + String(therm.object(), 2));
Serial.write('°'); // Degree Symbol
Serial.println("F");
Serial.print("Ambient: " + String(therm.ambient(), 2));
setLED(LOW);
void setLED(bool on)
if (on)
digitalWrite(LED_PIN, LOW);
digitalWrite(LED_PIN, HIGH);
SECTION OF SRC REFERRED TO IN ERROR:
uint8_t IRTherm::sleep(void)
// Calculate a crc8 value.
// Bits sent: _deviceAddress (shifted left 1) + 0xFF
uint8_t crc = crc8(0, (_deviceAddress << 1));
crc = crc8(crc, MLX90614_REGISTER_SLEEP);
// Manually send the sleep command:
Wire.beginTransmission(_deviceAddress);
Wire.write(MLX90614_REGISTER_SLEEP);
Wire.write(crc);
Wire.endTransmission(true);
// Set the SCL pin LOW, and SDA pin HIGH (should be pulled up)
pinMode(SCL, OUTPUT);
digitalWrite(SCL, LOW);
pinMode(SDA, INPUT);
uint8_t IRTherm::wake(void)
// Wake operation from datasheet. (Doesn't seem to be working.)
pinMode(SCL, INPUT); // SCL high
pinMode(SDA, OUTPUT);
digitalWrite(SDA, LOW); // SDA low
delay(50); // delay at least 33ms
pinMode(SDA, INPUT); // SDA high
delay(250);
// PWM to SMBus mode:
digitalWrite(SCL, LOW); // SCL low
delay(10); // Delay at least 1.44ms
Wire.begin();
Arduino: 1.6.5 (Windows 8.1), Board: "Adafruit Feather M0 (Native USB Port)"
Build options changed, rebuilding all
C:\Users\kward\Documents\Arduino\libraries\SparkFun_MLX90614_Arduino_Library-master\src\SparkFunMLX90614.cpp: In member function 'uint8_t IRTherm::sleep()':
C:\Users\kward\Documents\Arduino\libraries\SparkFun_MLX90614_Arduino_Library-master\src\SparkFunMLX90614.cpp:276:10: error: 'SCL' was not declared in this scope
C:\Users\kward\Documents\Arduino\libraries\SparkFun_MLX90614_Arduino_Library-master\src\SparkFunMLX90614.cpp:278:10: error: 'SDA' was not declared in this scope
C:\Users\kward\Documents\Arduino\libraries\SparkFun_MLX90614_Arduino_Library-master\src\SparkFunMLX90614.cpp: In member function 'uint8_t IRTherm::wake()':
C:\Users\kward\Documents\Arduino\libraries\SparkFun_MLX90614_Arduino_Library-master\src\SparkFunMLX90614.cpp:284:10: error: 'SCL' was not declared in this scope
C:\Users\kward\Documents\Arduino\libraries\SparkFun_MLX90614_Arduino_Library-master\src\SparkFunMLX90614.cpp:285:10: error: 'SDA' was not declared in this scope
Error compiling.
enabled in File > Preferences.
