MLX90620 / MLX90621 - 16X4 pixel IR thermal array
kami83: i am also really interested in building my own cheap camera, but i cannot get any sensor here in Germany. Is there any chance to get some? Any tips?
Sourcing the part seems to be a problem. I ordered one here from as-electronic (Germany): http://as-electronic.net/shop/article_MLX90620ESF-BAD/MLX90620ESF-BAD-16x4-IR-Matrix-Temperatursensor.html?sessid=00GGQRHtRxMwPyV6emEwYDQGYumL5IhN16aK7VHOgiTEIWxkFn615nzhkErgWGDs&shop_param=cid%3D18%26aid%3DMLX90620ESF-BAD%26
Shipped within two days.
Below are the temperature values I get. The sensor is pointing towards a wall, so the temperatures should be almost the same.
-43.29 -25.06 -20.19 -14.03 -17.91 -9.14  -28.29 -14.59 -13.57 0.49   -4.85  -14.13 -10.58 -0.23  -2.00  -4.07
-16.22 6.06   3.53   -4.15  2.72   8.47   2.10   -3.24  1.14   7.40   9.65   1.90   -7.16  7.83   6.58   3.11
3.07   6.51   8.03   1.24   3.46   0.64   8.97   0.92   1.76   7.03   4.71   3.91   7.54   12.93  7.92   7.25
-7.14  5.69   8.91   4.91   4.54   5.32   8.59   1.41   5.62   8.11   10.34  2.61   6.35   -8.17  0.14   1.68
This is the calibration information from my sensor:
a_ij:
-87 -82 -86 -84 -78 -76 -70 -74 -74 -71 -71 -69 -72 -66 -66 -70
-66 -65 -65 -68 -70 -64 -62 -64 -63 -59 -62 -64 -58 -59 -58 -62
-60 -59 -56 -57 -57 -51 -55 -52 -53 -50 -53 -54 -54 -50 -49 -51
-45 -45 -48 -47 -47 -43 -44 -48 -48 -43 -45 -42 -45 -39 -44 -44
b_ij:
-60 -60 -60 -68 -51 -55 -51 -60 -51 -51 -51 -68 -60 -43 -43 -51
-47 -51 -47 -43 -34 -51 -43 -51 -47 -43 -43 -47 -43 -43 -43 -43
-43 -43 -43 -77 -34 -38 -43 -51 -38 -43 -43 -38 -43 -34 -34 -34
-38 -34 -43 -34 -34 -34 -34 -34 -30 -30 -34 -30 -34 -38 -43 -30
alpha_ij:
1.01E-8 1.29E-8 1.37E-8 1.36E-8 1.16E-8 1.48E-8 1.35E-8 1.48E-8 1.26E-8 1.57E-8 1.54E-8 1.50E-8 1.37E-8 1.53E-8 1.60E-8 1.61E-8
1.41E-8 1.69E-8 1.71E-8 1.65E-8 1.61E-8 1.78E-8 1.79E-8 1.69E-8 1.56E-8 1.75E-8 1.84E-8 1.82E-8 1.55E-8 1.84E-8 1.89E-8 1.82E-8
1.68E-8 1.94E-8 1.91E-8 1.90E-8 1.66E-8 1.79E-8 1.89E-8 1.76E-8 1.64E-8 1.77E-8 1.84E-8 1.73E-8 1.65E-8 1.66E-8 1.68E-8 1.68E-8
1.36E-8 1.57E-8 1.65E-8 1.51E-8 1.49E-8 1.49E-8 1.57E-8 1.54E-8 1.46E-8 1.41E-8 1.47E-8 1.29E-8 1.30E-8 1.26E-8 1.39E-8 1.29E-8
If you compare the calibration information (espc. a_ij and b_ij) with the temperature you will notice a correlation. Is my sensor miscalibrated? If you have such an sensor, please print the calibration data and post it here. I'd like to know if other sensors have the same huge variance between each pixel.
EDIT: This was caused by useing 3.3V instead of the recommended 2.6V supply, despite that fact the specification says "3.6V max" :(
small patch to calculate alpha_ij on the Arduino instead of a spreadsheet :slight_smile:
  float da0_scale = pow(2, -EEPROM_DATA[0xe3]);
  float alpha_const = (float)(((unsigned int)EEPROM_DATA[0xe1] << 8) + (unsigned int)EEPROM_DATA[0xe0]) * pow(2, -EEPROM_DATA[0xe2]);
  for(int i=0; i<=63; i++) {
    float alpha_var = (float)EEPROM_DATA[0x80 + i] * da0_scale;
    alpha_ij[i] = (alpha_const + alpha_var);
Add it before the end of “void varInitialization(byte EEPROM_DATA)”.
Hi maxbot and IlBaboomba - thank you very much for the example code! It got me started very quickly. I hope you don’t mind, but I added quite a few comments so I could better understand the code. I also created a sketch to calculate the alphas.
The repo is here: https://github.com/nseidle/MLX90620_Example
One main improvement was the removal of float v_ir_tgc_comp[64]. v_ir_tgc_comp is only calculated once so an array of floats can be removed. This saves a good pile (256bytes) of RAM.
Let me know if you see any problems or changes that can be made. This is a neat (but expensive!) little sensor.
-Nathan
//Calculate the temperatures seen for each pixel
//Relies on the raw irData array
//Returns an 64-int array called temperatures
void calculate_TO()
  float v_ir_off_comp;
  float v_ir_tgc_comp;
  float v_ir_comp;
  //Calculate the offset compensation for the one compensation pixel
  //This is a constant in the TO calculation, so calculate it here.
  int cpix = readCPIX_MLX90620(); //Go get the raw data of the compensation pixel
  float v_cp_off_comp = (float)cpix - (a_cp + (b_cp/pow(2, b_i_scale)) * (Tambient - 25));
  for (int i = 0 ; i < 64 ; i++)
    v_ir_off_comp = irData[i] - (a_ij[i] + (float)(b_ij[i]/pow(2, b_i_scale)) * (Tambient - 25)); //#1: Calculate Offset Compensation
    v_ir_tgc_comp = v_ir_off_comp - ( ((float)tgc/32) * v_cp_off_comp); //#2: Calculate Thermal Gradien Compensation (TGC)
    v_ir_comp = v_ir_tgc_comp / emissivity; //#3: Calculate Emissivity Compensation
    temperatures[i] = sqrt( sqrt( (v_ir_comp/alpha_ij[i]) + pow(Tambient + 273.15, 4) )) - 273.15;
just got the chance to order a Panasonic GRID-Eye AMG8851 (5 Volt) or AMG8831 (3.3 Volt).
What did you think which one is better the MLX or the GRID-Eye?
Thanks a lot.
Cu kami83
kami83: Hi,
i would like to make good picture for a distance like 1-2 meters. What is with a Lens? Do i need one?
Thx a lot.
Cu kami
Probably a bit late to answer the question but it could help others. I can't remember where I read it but if my memory don't fool me, the MLX90620 works in the 5µm to 16µm range. At those wavelength glass is black so you can't use classical optics.
Hi all
I have been following this post for awhile and decided to try and implement the thermocam on the cheap thermocam website with the MLX90620. Using the some of the code on that site and Nathan’s code I develop a Processing sketch and an associated Arduino sketch for the way I set things up. Since I borrowed so much of the code from the posts I decided to share what I have so far. Its operational but not perfect.
Here is the link: https://drive.google.com/folderview?id=0BwzZjH9KYYMDcXZEVmxUamY5ZEU&usp=sharing
Hope this helps.
Thermal_Imager Processing Sketch.7z (9.37 KB)
Hi CyberMerln and all,
Thank you for the information. I also did some tests with the MLX90620-BAB. I was a bit disappointed by the results but I certainly still have code/configuration/tuning issues.
One simple test that fails is to light up a candle and (manually) move the sensor around so that each of the 64 pixel picks up the heat according to the move.
I do not currently have the time to investigate more but I was wondering if such a simple test worked ok for others (and I guess so!).
BTW, I did not use the spreadsheet but the code rmie posted earlier.
Cheers
thanks a lot for the answer. I am still thinking about buying the MLX90620 or the Grideye?
Cu kami
Thanks for all the information and code. I am trying to get this working on an arduino Mega2560, but it is not communicating at all. Do I have to change something since the SDA/SCL ports (20 & 21) are different? I also found according to the schematic that there are 2 hardware resistors pulled to +5v on the SDA and SCL ports. Could that be the issue?
Thanks!
Sorry, there were no changes required, I just had it wired wrong. :blush: Got it working now. Thanks!
Hello,
I would greatly appreciate guidance with the following problem: There is no data being printed to the Serial Monitor (I have checked the speed and it is correctly set at 115200 baud).
The code for the Sketch I am refering to is at the bottom of this post. Reference: Arduino and MLX90620 16X4 pixel IR thermal array - Reply #11 on: December 25, 2012, 03:35:30 pm http://forum.arduino.cc/index.php?topic=126244.0
I am very new to programming and the Arduino and would appreciate your guidance to get the “Arduino and MLX90620 16X4 pixel IR thermal array” Sketch running. I have the Sketch and the library loaded into the Arduino IDE, the Sketch compiles and uploads to the Arduino with out generating any error messages.
The following is the configuration of the hardware:
Arduino: “OSEPP Uno R3 Plus board” http://osepp.com/products/arduino-compatible-boards/uno-r3-plus/
Sensor: MLX90620 16x4 IR array used on the RoBoard Module RM-G212 http://www.roboard.com/G212.html
I have confirmed that the Arduino and MLX90620 on the RoBoard Module RM-G212 are communicating via i2c by using a Sketch that reports all the addresses avaliable on an i2c device. Results are as follows:
Scanning…
I2C device found at address 0x50 !
I2C device found at address 0x51 !
I2C device found at address 0x52 !
I2C device found at address 0x53 !
I2C device found at address 0x54 !
I2C device found at address 0x55 !
I2C device found at address 0x56 !
I2C device found at address 0x57 !
I2C device found at address 0x60 !
done
Your help will be greatly appreciated.
 * Attention! I commented out the alpha_ij array, so if you're going to compile the sketch you'll get for sure an error.
 * You should replace all 64 values with the alpha_ij calculated using the values stored in your MLX90620's EEPROM.
 * I suggest you to make an EEPROM dump, print it on the Serial port and store it in a file. From there, with the help of a spreadsheet (Libreoffice, Google Docs, Excel...) calculate your own alpha_ij values.
 * Please also pay attention to your emissivity value: since in my case it was equal to 1, to save SRAM i cut out that piece of calculation. You need to restore those lines if your emissivity value is not equal to 1.
#include <i2cmaster.h>
int freq = 16;  //Set this value to your desired refresh frequency
int IRDATA[64];
byte CFG_LSB, CFG_MSB, PTAT_LSB, PTAT_MSB, CPIX_LSB, CPIX_MSB, PIX_LSB, PIX_MSB;
int PIX, v_th, CPIX;
float ta, to, emissivity, k_t1, k_t2;
float temperatures[64];
int count=0;
unsigned int PTAT;
int a_cp, b_cp, tgc, b_i_scale;
int a_ij[64];
int b_ij[64];
//float alpha_ij[64] = {1.591E-8, 1.736E-8, 1.736E-8, 1.620E-8, 1.783E-8, 1.818E-8, 1.992E-8, 1.748E-8, 1.864E-8, 2.056E-8, 2.132E-8, 2.033E-8, 2.097E-8, 2.324E-8, 2.388E-8, 2.161E-8, 2.155E-8, 2.394E-8, 2.353E-8, 2.068E-8, 2.353E-8, 2.633E-8, 2.708E-8, 2.394E-8, 2.499E-8, 2.778E-8, 2.731E-8, 2.580E-8, 2.539E-8, 2.796E-8, 2.871E-8, 2.598E-8, 2.586E-8, 2.801E-8, 2.830E-8, 2.633E-8, 2.609E-8, 2.894E-8, 2.924E-8, 2.633E-8, 2.464E-8, 2.778E-8, 2.894E-8, 2.673E-8, 2.475E-8, 2.737E-8, 2.796E-8, 2.679E-8, 2.394E-8, 2.708E-8, 2.714E-8, 2.644E-8, 2.347E-8, 2.563E-8, 2.493E-8, 2.388E-8, 2.179E-8, 2.440E-8, 2.504E-8, 2.295E-8, 2.033E-8, 2.283E-8, 2.295E-8, 2.155E-8};  //<-- REPLACE THIS VALUES WITH YOUR OWN!
//float v_ir_off_comp[64];  //I'm going to merge v_ir_off_comp calculation into v_ir_tgc_comp equation. It's not required anywhere else, so I'll save 256 bytes of SRAM doing this.
float v_ir_tgc_comp[64];
//float v_ir_comp[64];		//removed to save SRAM, in my case v_ir_comp == v_ir_tgc_comp
void config_MLX90620_Hz(int Hz){
  byte Hz_LSB;
  switch(Hz){
    case 0:
      Hz_LSB = B00001111;
    case 1:
      Hz_LSB = B00001110;
    case 2:
      Hz_LSB = B00001101;
    case 4:
      Hz_LSB = B00001100;
    case 8:
      Hz_LSB = B00001011;
    case 16:
      Hz_LSB = B00001010;
    case 32:
      Hz_LSB = B00001001;
    default:
      Hz_LSB = B00001110;
  i2c_start_wait(0xC0);
  i2c_write(0x03);
  i2c_write((byte)Hz_LSB-0x55);
  i2c_write(Hz_LSB);
  i2c_write(0x1F);
  i2c_write(0x74);
  i2c_stop();
void read_EEPROM_MLX90620(){
  byte EEPROM_DATA[256];
  i2c_start_wait(0xA0);
  i2c_write(0x00);
  i2c_rep_start(0xA1);
  for(int i=0;i<=255;i++){
    EEPROM_DATA[i] = i2c_readAck();
  i2c_stop();
  varInitialization(EEPROM_DATA);
  write_trimming_value(EEPROM_DATA[247]);
void write_trimming_value(byte val){
  i2c_write(0x04);
  i2c_write((byte)val-0xAA);
  i2c_write(val);
  i2c_write(0x56);
  i2c_write(0x00);
  i2c_stop();
void calculate_TA(){
  ta = (-k_t1 + sqrt(square(k_t1) - (4 * k_t2 * (v_th - (float)PTAT))))/(2*k_t2) + 25; 	//it's much more simple now, isn't it? :)
void calculate_TO(){
  float v_cp_off_comp = (float) CPIX - (a_cp + (b_cp/pow(2, b_i_scale)) * (ta - 25)); //this is needed only during the to calculation, so I declare it here.
  for (int i=0; i<64; i++){
    v_ir_tgc_comp[i] = IRDATA[i] - (a_ij[i] + (float)(b_ij[i]/pow(2, b_i_scale)) * (ta - 25)) - (((float)tgc/32)*v_cp_off_comp);
    //v_ir_comp[i]= v_ir_tgc_comp[i] / emissivity;									//removed to save SRAM, since emissivity in my case is equal to 1.
    //temperatures[i] = sqrt(sqrt((v_ir_comp[i]/alpha_ij[i]) + pow((ta + 273.15),4))) - 273.15;
    temperatures[i] = sqrt(sqrt((v_ir_tgc_comp[i]/alpha_ij[i]) + pow((ta + 273.15),4))) - 273.15;	//edited to work with v_ir_tgc_comp instead of v_ir_comp
void read_IR_ALL_MLX90620(){
  i2c_write(0x02);
  i2c_write(0x00);
  i2c_write(0x01);
  i2c_write(0x40);
  i2c_rep_start(0xC1);
  for(int i=0;i<=63;i++){
    PIX_LSB = i2c_readAck();
    PIX_MSB = i2c_readAck();
    IRDATA[i] = (PIX_MSB << 8) + PIX_LSB;
  i2c_stop();
void read_PTAT_Reg_MLX90620(){
  i2c_write(0x02);
  i2c_write(0x90);
  i2c_write(0x00);
  i2c_write(0x01);
  PTAT_LSB = i2c_readAck();
  PTAT_MSB = i2c_readAck();
  i2c_stop();
  PTAT = ((unsigned int)PTAT_MSB << 8) + PTAT_LSB;
void read_CPIX_Reg_MLX90620(){
  i2c_write(0x02);
  i2c_write(0x91);
  i2c_write(0x00);
  i2c_write(0x01);
  CPIX_LSB = i2c_readAck();
  CPIX_MSB = i2c_readAck();
  i2c_stop();
  CPIX = (CPIX_MSB << 8) + CPIX_LSB;
void read_Config_Reg_MLX90620(){
  i2c_write(0x02);
  i2c_write(0x92);
  i2c_write(0x00);
  i2c_write(0x01);
  CFG_LSB = i2c_readAck();
  CFG_MSB = i2c_readAck();
  i2c_stop();
void check_Config_Reg_MLX90620(){
  read_Config_Reg_MLX90620();
  if ((!CFG_MSB & 0x04) == 0x04){
    config_MLX90620_Hz(freq);
void varInitialization(byte EEPROM_DATA[]){
  v_th = (EEPROM_DATA[219] <<8) + EEPROM_DATA[218];
  k_t1 = ((EEPROM_DATA[221] <<8) + EEPROM_DATA[220])/1024.0;
  k_t2 =((EEPROM_DATA[223] <<8) + EEPROM_DATA[222])/1048576.0;
  a_cp = EEPROM_DATA[212];
  if(a_cp > 127){
    a_cp = a_cp - 256;
  b_cp = EEPROM_DATA[213];
  if(b_cp > 127){
    b_cp = b_cp - 256;
  tgc = EEPROM_DATA[216];
  if(tgc > 127){
    tgc = tgc - 256;
  b_i_scale = EEPROM_DATA[217];
  emissivity = (((unsigned int)EEPROM_DATA[229] << 8) + EEPROM_DATA[228])/32768.0;
    a_ij[i] = EEPROM_DATA[i];
    if(a_ij[i] > 127){
      a_ij[i] = a_ij[i] - 256;
    b_ij[i] = EEPROM_DATA[64+i];
    if(b_ij[i] > 127){
      b_ij[i] = b_ij[i] - 256;
void Temperatures_Serial_Transmit(){
    Serial.println(temperatures[i]);
void setup(){
  pinMode(13, OUTPUT);
  i2c_init();
  PORTC = (1 << PORTC4) | (1 << PORTC5);
  delay(5);
  read_EEPROM_MLX90620();
void loop(){
  if(count ==0){		//TA refresh is slower than the pixel readings, I'll read the values and computate them not every loop.
    read_PTAT_Reg_MLX90620();
    calculate_TA();
    check_Config_Reg_MLX90620();
  count++;
  if(count >=16){
    count = 0;
  read_IR_ALL_MLX90620();
  read_CPIX_Reg_MLX90620();
  calculate_TO();
  Temperatures_Serial_Transmit();
Cheers, Bob
I am attempting to use the MLX90602 sketch found on the Arduino Forum: http://forum.arduino.cc/index.php?topic=126244.0 « Reply #2 on: October 10, 2012, 03:38:33 am »» .
Question: I have included the required library (i2cmaster.h )is included in the sketch, however I have been told that there are many versions floating around – possibly I have one that does not function correctly resulting in a compile error message (below)?
Request: Would it be possible for someone to direct me to a copy of i2cmaster.h that is known to work with this sketch?
Currently, the i2cmaster.h library I am using results in the following compile error message:
processing.app.debug.RunnerException at processing.app.debug.Compiler.getCommandCompilerS(Compiler.java:498) at processing.app.debug.Compiler.compileFiles(Compiler.java:201) at processing.app.debug.Compiler.compileLibraries(Compiler.java:590) at processing.app.debug.Compiler.compile(Compiler.java:97) at processing.app.Sketch.build(Sketch.java:1572) at processing.app.Sketch.build(Sketch.java:1551) at processing.app.Editor$DefaultRunHandler.run(Editor.java:1925) at java.lang.Thread.run(Thread.java:619)
My development environment:
Arduino: Hardware: OSEPP Uno R3 Plus Software: IDE 1.5.2
MLX90602: MLX90620 16x4 IR array used on the RoBoard Module RM-G212 http://www.roboard.com/G212.html
PC: Hardware: Lenovo ideacenter Processor: i7-2600 @ 3.40 Ghz RAM: 8.00 GB System: 64 bit
Software: Windows Home Premium, with Service pack 1 installed All current Windows7 updates installed
Hi Bob,
I was having the same problem. I found this page:
http://bildr.org/2011/02/mlx90614-arduino/
There is a link to a version of i2cmaster that is compatible with the forum sketch.
Neil
Hi Neil,
Thanks for the information. As it turns out I found this last week and didn't think to post what I found back on the Forum. How is you project going?
thanks again,
Bob
I’m interested in this thermal sensor of yours.
I’m looking to detect a change in temperature of a mass of air in the sky (a thermal that provides lift for a glider). This would be several hundred yards away. Would you device recognize this?
It wouldn't work. The air in the thermal is transparent, so it neither absorbs nor radiates any light. The thermal might be warmer, but since it is not generating any infrared it cannot be seen by an infrared imager.
I am trying to implement the code provided (mega thanks for sharing your work!) but the code freezes on the command
i2c_start_wait(MLX90620_EEPROM_WRITE);
I am using the I2CMaster library from the MLX90614 forum, which works for that sensor, because the link in this thread is dead now. Has anyone had a similar experience?
I am using an Arduino Uno with an MLX90620 and the code from this forum exactly as provided.
Thank you so much for your help!
Richard
I was confusing the bottom view for the top view in the data sheet, thus my wiring was backwards. It is working now! XD Super big thanks again for contributing your work!
Richard
hello everyone. very interesting this thread is very helpful. I am making an application with the MLX90620 with opencv in linux, I am testing the example of nseidle that is very well documented. The problem that some erroneous pixels and negative values ??pull. It can be a noise problem? I have to use a lens to filter interference?? These are the calcuation alpha data and some temperature readings:
alpha0: 33030
alpha0_scale: 41
delta_alpha_scale: 34
emissitivity: 1.00000
Copy and paste the following block of text into the MLX90620_Example sketch:
  1.51949E-8, 1.64173E-8, 1.58352E-8, 1.50203E-8, 1.75814E-8, 1.88038E-8, 1.86292E-8, 1.72322E-8,
  2.00262E-8, 2.07829E-8, 2.06082E-8, 1.89784E-8, 2.20052E-8, 2.29948E-8, 2.28201E-8, 2.10157E-8,
  2.38097E-8, 2.43917E-8, 2.43917E-8, 2.28201E-8, 2.52066E-8, 2.56141E-8, 2.49738E-8, 2.28201E-8,
  2.59633E-8, 2.59633E-8, 2.56141E-8, 2.31694E-8, 2.53813E-8, 2.66036E-8, 2.61962E-8, 2.31694E-8,
  2.57887E-8, 2.66036E-8, 2.61962E-8, 2.29948E-8, 2.61962E-8, 2.66036E-8, 2.61962E-8, 2.25873E-8,
  2.63708E-8, 2.59633E-8, 2.57887E-8, 2.24127E-8, 2.61962E-8, 2.57887E-8, 2.49738E-8, 2.15978E-8,
  2.49738E-8, 2.57887E-8, 2.47992E-8, 2.09575E-8, 2.43917E-8, 2.47992E-8, 2.38097E-8, 1.99680E-8,
  2.34022E-8, 2.38097E-8, 2.25873E-8, 1.92113E-8, 2.17724E-8, 2.21798E-8, 2.13649E-8, 1.77561E-8,
45.05, 49.02, 24.12, 17.72, -32.80, 8.95, nan, 33.00, 51.56, 53.42, 52.29, 51.43, 53.97, 53.44, 58.38, 53.99,
38.36, 53.60, 53.60, 52.93, 54.30, 55.94, 54.60, 52.07, 54.93, 55.67, 55.19, 56.01, 56.62, 56.56, 56.10, 56.01,
54.90, 55.81, 56.82, 55.12, 56.10, 56.21, 55.74, 54.89, 56.51, 56.77, 56.73, 57.04, 56.82, 58.18, 56.14, 55.85,
57.65, 57.82, 55.63, 56.99, 57.52, 57.24, 58.49, 58.47, 55.67, 57.78, 56.67, 55.94, 56.43, 56.55, 55.41, 57.92,
47.81, 50.26, 22.41, 23.29, -25.35, 14.70, nan, 33.70, 52.55, 54.82, 52.76, 52.99, 55.28, 54.28, 55.90, 55.82,
40.73, 55.58, 55.97, 55.90, 56.58, 57.78, 55.76, 53.79, 57.13, 56.40, 56.31, 54.77, 56.62, 57.27, 55.74, 55.18,
56.38, 56.53, 57.90, 56.78, 56.82, 58.68, 56.10, 57.84, 57.58, 57.49, 55.62, 57.04, 57.18, 57.09, 56.14, 56.73,
57.65, 58.18, 58.67, 57.88, 56.75, 57.99, 58.49, 56.59, 56.49, 57.39, 55.83, 56.93, 55.55, 57.82, 56.30, 56.86,
46.44, 47.76, 24.96, 17.72, -34.39, 10.63, nan, 33.00, 52.55, 54.35, 51.80, 50.90, 53.97, 53.86, 55.90, 54.91,
37.88, 54.00, 54.00, 52.93, 54.68, 55.19, 53.44, 53.36, 55.30, 55.67, 54.82, 54.77, 55.88, 56.56, 55.74, 54.77,
55.64, 55.45, 56.10, 55.12, 56.46, 56.56, 56.46, 56.59, 56.51, 55.30, 56.36, 55.77, 57.18, 56.36, 56.52, 56.29,
57.28, 56.36, 56.02, 56.54, 55.58, 55.71, 56.52, 56.59, 56.49, 56.99, 57.50, 56.44, 56.43, 57.40, 56.30, 56.86,
in same pixels the value is negative, and other is nan. Are broken these pixels on my sensor? :~ thanks for helping :)
