MLX90620 "replacement"
does exist any similar far-IR senzor like Melexis MLX90620? By similar I mean far-IR senzor with bigger resolution than 1x1 and meaningful frame rate, at least 50 Hz.
Do you want a complete thermographic camera ?
What is your budget ?
No, I dont want whole camera, just far IR sensor, thats all. Something like that Melexis one... just asking, cause I do not believe it's olnly manufacturer selling it. I have found some products of another companies but none of them is obtainable fora single man. My goal is to make movement detector with possibilities, which cant be done with 1x1 sensors...
You should have told what you found, so I don't have to do the same thing.
I remember seeing this project on kickstarter:
It uses a 16x4 thermal sensor. After some searching, I found a number of those, and some can normally be bought by customers like you and me.
This is a selection of what I found:
http://www.melexis.com/MLX90620
http://www.mclarenelectronics.com/Products/Product/Temperature%20Sensor-16x4%20Infra-Red%20Array
http://www.robotshop.com/en/roboard-rm-g212-thermal-array-sensor.html
Is this what you want to know ?
Yeah, that's looking like the one I need. The firts you mentioned from RH Worskhop is the one i wrote in Subject of a question. It's really good thing, but price is quite high.
