MMA7455 g-force
hey all,
I'm currently working on this project that uses the MMA7455 accelerometer using I2C to the arduino. My goal for this project is to obtain the accelerations and use them to calculate g-force and save on a sd card. Currently, I am having trouble getting the accelerations positive and negative. I just get values from 0 to 255. I have everything else working that i need except this. So I'm asking if you all can help me out.
Thanks in advance.
Here's my code
#include <Wire.h>
#include <SD.h>
#define ACCELEROMETER 0x1D //Address for Accelerometer
//REGISTERS
#define MODE_CONTROL  0x16 //Mode control register
#define PULSE_DET     0x1B //Pulse detection threshold limit value
#define X_OUT         0x06 //8 bit register containing value for X
#define Y_OUT         0x07 //8 bit register containing value for Y
#define Z_OUT         0x08 //8 bit register containing value for Z
#define DETECTION     0x19 //Detection source register
#define THRESHOLD     0x18 // setting the threshold to be based on the threshold value as positive or negative
//VALUES
//#define Z_PULSE       0x40 //Pulse detected on Z-axis
#define SENSEVALUE    0x05 // Measurement mode to write to Mode Control
#define level    0x1A
File myFile;
int but2 = 7;
int but = 8;
int rdyPin = 9;
int reading, reading2;
int previous = LOW;
double force;
int mass = 20;
int val;
//required setup function
  Wire.begin();
  accWrite(MODE_CONTROL, SENSEVALUE); //writes measurement mode to mode control
  accWrite(DETECTION, 0x00); // setting up for motion detection
  accWrite(THRESHOLD, 0x00);
  accWrite(level, 0x2F);
  Serial.print("Initializing SD card...."); //getting SD card ready
  pinMode(10, OUTPUT);
  pinMode(but, INPUT);
  pinMode(rdyPin, OUTPUT);
  pinMode(but2, INPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
   Serial.println("initialization done.");
   myFile = SD.open("accellog.csv", FILE_WRITE);
    // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to accellog.csv ");
                              ///String header = "xVal, yVal, zVal";
       myFile.println("X, Y, Z");                              //myFile.println(header);
	// close the file:
    myFile.close();
    Serial.println("header");
    // if the file didn't open, print an error:
    Serial.println("error opening file");
  /* re-open the file for reading:
  myFile = SD.open("accellog_1.csv");
  if (myFile) {
    Serial.println("accellog_1.csv:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
    	Serial.write(myFile.read());
    // close the file:
    myFile.close();
    Serial.println("error opening accellog_1.csv");
  while(digitalRead(but)== HIGH)
  digitalWrite(rdyPin, LOW);
  while (digitalRead(but2)== HIGH)
   //force = mass*X_OUT;
  //Serial.println(force);
    //Data string for storing to SD card
  // Use CSV format
  /*Serial.print("X: ");
  Serial.print(accRead(X_OUT));
  Serial.print("   Y: ");
  Serial.print(accRead(Y_OUT));
  Serial.print("   Z: ");
  Serial.println(accRead(Z_OUT));
  delay(100);
  //String dataString =  String(accRead(X_OUT)) + "," + String(accRead(Y_OUT)) + "," + String(accRead(Z_OUT));
   digitalWrite(rdyPin, HIGH);
 File myFile = SD.open("accellog.csv", FILE_WRITE);
  if (myFile)
     myFile.print (accRead(X_OUT));  // myFile.println(dataString);
     myFile.print (",");
     myFile.print (accRead(Y_OUT));
     myFile.print (",");
     myFile.println (accRead(Z_OUT));
    myFile.close();
    //Serial.println(dataString);
    Serial.print (accRead(X_OUT));  // myFile.println(dataString);
     Serial.print (",");
     Serial.print (accRead(Y_OUT));
     Serial.print (",");
     Serial.println (accRead(Z_OUT));
    //Serial.println("Could not open file");
  delay(50);
void accWrite(byte address, byte data) {
  Wire.beginTransmission(ACCELEROMETER);
  Wire.write(address);
  Wire.write(data);
  Wire.endTransmission();
//function to read byte data from a register
unsigned int accRead(byte address){
  byte val = 0x00;
  Wire.requestFrom(ACCELEROMETER, 1);
  if(Wire.available() > 0) {
    val = Wire.read();
  return val;
// 	MMA 7455 pin
//	1 - VIN to Arduino 3.3V
//	5 - GND, ground to Arduino GND
//	6 - Chip Select - connect this to 5V with a 1K resistor, this selects I2C mode
//	7 - Data - connect this to the ATmega's SDA (data line) on analog input pin 4, with 4.7K pull up resistor
//	8 - Clock - connect this to ATmega's SCL (clock line) on analog input pin 5, with 4.7K pull up resistor
If you are using it in 8-bit mode then you just need to cast the result to a char, which is a signed datatype. 0x00..0x7F represents 0 to +127, 0xFF..0x80 represents -1..-128
:DThanks alot!!! now I need to just get it to output the accelerations in according to the force.
If there are 0.016g per count and there are 256 counts. Wouldn't i just multiply the output by 0.016 to get the output to be something like +0.5g???
yes, if you want the output in g.
If someone is still reading this, I have just made a page for the MMA7455: Arduino Playground - MMA7455
The 10-bits values are converted to normal 16-bit integers, and those are converted to floating point 'g'-forces.
There is a new How-To page and software examples for the MMA7544 here:
http://arduino-info.wikispaces.com/accelerometer-MMA7455
