Hi I’m trying to read data from Adafruit MMA8451 accelerometer and Adafruit Tmp006 together. I can work either on their own without changing waiting as I have them wired in parallel correct to serial clock and serial data lines . Unfortunately after days of research I still can’t combine the 2 sensors in one programme . Any advice or help would be greatly appreciated thanks
We can't see:
a) your code
b) your schematic
And please don't hijack unrelated topics.
Acceleromotor code
@file Adafruit_MMA8451.h
@author K. Townsend (Adafruit Industries)
@license BSD (see license.txt)
This is an example for the Adafruit MMA8451 Accel breakout board
----> Adafruit Triple-Axis Accelerometer - ±2/4/8g @ 14-bit - MMA8451 : ID 2019 : $7.95 : Adafruit Industries, Unique & fun DIY electronics and kits
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
@section HISTORY
v1.0 - First release
#include <Wire.h>
#include <Adafruit_MMA8451.h>
#include <Adafruit_Sensor.h>
Adafruit_MMA8451 mma = Adafruit_MMA8451();
void setup(void) {
Serial.println("Adafruit MMA8451 test!");
if (! mma.begin()) {
Serial.println("Couldnt start");
while (1);
Serial.println("MMA8451 found!");
mma.setRange(MMA8451_RANGE_2_G);
Serial.print("Range = "); Serial.print(2 << mma.getRange());
Serial.println("G");
// Read the 'raw' data in 14-bit counts
mma.read();
Serial.print("X:\t"); Serial.print(mma.x);
Serial.print("\tY:\t"); Serial.print(mma.y);
Serial.print("\tZ:\t"); Serial.print(mma.z);
/* Get a new sensor event */
sensors_event_t event;
mma.getEvent(&event);
/* Display the results (acceleration is measured in m/s^2) */
Serial.print("X: \t"); Serial.print(event.acceleration.x); Serial.print("\t");
Serial.print("Y: \t"); Serial.print(event.acceleration.y); Serial.print("\t");
Serial.print("Z: \t"); Serial.print(event.acceleration.z); Serial.print("\t");
Serial.println("m/s^2 ");
/* Get the orientation of the sensor */
uint8_t o = mma.getOrientation();
switch (o) {
case MMA8451_PL_PUF:
Serial.println("Portrait Up Front");
case MMA8451_PL_PUB:
Serial.println("Portrait Up Back");
case MMA8451_PL_PDF:
Serial.println("Portrait Down Front");
case MMA8451_PL_PDB:
Serial.println("Portrait Down Back");
case MMA8451_PL_LRF:
Serial.println("Landscape Right Front");
case MMA8451_PL_LRB:
Serial.println("Landscape Right Back");
case MMA8451_PL_LLF:
Serial.println("Landscape Left Front");
case MMA8451_PL_LLB:
Serial.println("Landscape Left Back");
Temperature Sensor Code
This is an example for the TMP006 Contact-less Infrared Thermopile Sensor
Designed specifically to work with the Adafruit TMP006 Breakout
----> Contact-less Infrared Thermopile Sensor Breakout - TMP006 : ID 1296 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits
These displays use I2C to communicate, 2 pins are required to
interface
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include "Adafruit_TMP006.h"
// Connect VCC to +3V (its a quieter supply than the 5V supply on an Arduino
// Gnd -> Gnd
// SCL connects to the I2C clock pin. On newer boards this is labeled with SCL
// otherwise, on the Uno, this is A5 on the Mega it is 21 and on the Leonardo/Micro digital 3
// SDA connects to the I2C data pin. On newer boards this is labeled with SDA
// otherwise, on the Uno, this is A4 on the Mega it is 20 and on the Leonardo/Micro digital 2
Adafruit_TMP006 tmp006;
//Adafruit_TMP006 tmp006(0x41); // start with a diferent i2c address!
Serial.println("Adafruit TMP006 example");
// you can also use tmp006.begin(TMP006_CFG_1SAMPLE) or 2SAMPLE/4SAMPLE/8SAMPLE to have
// lower precision, higher rate sampling. default is TMP006_CFG_16SAMPLE which takes
// 4 seconds per reading (16 samples)
if (! tmp006.begin()) {
Serial.println("No sensor found");
while (1);
Serial.println("Send s to enter sleep mode, or w to wake up. Measurements are not updated while asleep!");
// Check for sleep/wake command.
while (Serial.available() > 0) {
char c = Serial.read();
if (c == 'w') {
Serial.println("Waking up!");
tmp006.wake();
else if (c == 's') {
Serial.println("Going to sleep!");
tmp006.sleep();
// Grab temperature measurements and print them.
float objt = tmp006.readObjTempC();
//Serial.print("Object Temperature: ");
Serial.print(objt);
Serial.print("\t");
//Serial.println("*C");
float diet = tmp006.readDieTempC();
//Serial.print("Die Temperature: ");
Serial.println(diet);
delay(400); // 4 seconds per reading for 16 samples per reading
dont have image of schematic sorry but they are wired in parallel and either programme will work without changing the wiring .
Where's the combined code?
Please remember to use code tags when posting code
----> https://www.adafruit.com/products/2019
@section HISTORY
#include <Wire.h>
const int Adafruit_MMA8451 = 29;
const int Adafruit_TMP006 = 64;
void setup(void) {
if (!TMP006.begin(64)) {
while (1);
if (! mma.begin(29)) {
while (1);
void loop(){
if (c == 'w') {
64.wake();
64.sleep();
float objt = 64.readObjTempC();
Serial.print(objt);
Serial.print("\t");
float diet = 64.readDieTempC();
mma.read();
switch (o) {
break;[code]
#include <Wire.h>
// Gnd -> Gnd
int Adafruit_TMP006;
int Adafruit_MMA8451 = mma;
void setup(void) {
Wire.beginTransmission(Adafruit_TMP006); //Send a request to begin communication with the device at the specified address
Wire.write(0); //Sends a bit asking for register 0, the data register of the TC74 sensor
Wire.endTransmission(); //this ends transmission of data from the arduino to the temperature sensor
//this now reads the temperature from the tmp006 sensor
Wire.requestFrom(Adafruit_TMP006, 1);//this requests 1 byte from the specified address
while(Wire.available() == 0);
int celsius1= Wire.read();
Serial.print("Temperature sensor 1:");
Serial.print(celsius1);
Serial.print("degrees celsius ");
delay(2000);
while (1);
Wire.beginTransmission(Adafruit_MMA8451); //Send a request to begin communication with the device at the specified address
//this now reads the temperature from the TC74 sensor
Wire.requestFrom(Adafruit_MMA8451, 1);//this requests 1 byte from the specified address
int // Read the 'raw' data in 14-bit counts
mma.read();
switch (o) {
delay(2000);
