Hi, im trying to change the scale on this sensor. im using the example for changing the scale however when i try it doesnt work, it just stays at 2g
Does anyone know how to change this properly?
One thing ive noticed is that this is for the Q sensor however mine doesnt have this on the board but i also cant find any sort of libs for the none Q version that i have
Many thanks #
Library for the MMA8452Q
By: Jim Lindblom and Andrea DeVore
SparkFun Electronics
Do you like this library? Help support SparkFun. Buy a board!
https://www.sparkfun.com/products/14587
This sketch uses the SparkFun_MMA8452Q library to initialize
the accelerometer, change the scale, and stream calcuated x,
y, z, acceleration values from it (in g units).
Hardware hookup:
Arduino --------------- MMA8452Q Breakout
3.3V --------------- 3.3V
GND --------------- GND
SDA (A4) --\/330 Ohm\/-- SDA
SCL (A5) --\/330 Ohm\/-- SCL
The MMA8452Q is a 3.3V max sensor, so you'll need to do some
level-shifting between the Arduino and the breakout. Series
resistors on the SDA and SCL lines should do the trick.
License: This code is public domain, but if you see me
(or any other SparkFun employee) at the local, and you've
found our code helpful, please buy us a round (Beerware
license).
Distributed as is; no warrenty given.
#include <Wire.h> // Must include Wire library for I2C
#include "SparkFun_MMA8452Q.h" // Click here to get the library: http://librarymanager/All#SparkFun_MMA8452Q
MMA8452Q accel; // create instance of the MMA8452 class
Serial.println("MMA8452Q Change Scale Test Code!");
Wire.begin();
if (accel.begin() == false) {
Serial.println("Not Connected. Please check connections and read the hookup guide.");
while (1);
/* Default scale is +/-2g (full-scale range)
Set scale using SCALE_2G, SCALE_4G, SCALE_8G
Sets scale to +/-2g, 4g, or 8g respectively
accel.setScale(SCALE_4G);
if (accel.available()) { // Wait for new data from accelerometer
// Acceleration of x, y, and z directions in g units
//Serial.print(accel.getCalculatedX(), 3);
//Serial.print("\t");
Serial.println(accel.getCalculatedY(), 3);
// Serial.print("\t");
// Serial.print(accel.getCalculatedZ(), 3);
// Serial.println();
