Hi all,
I am currently trying to use a DUE board and SPI with an MMC5983MA magnetometer (data sheet linked below). Using an analog discovery 2, I was able to see the binary readout that I was sending to the chip, and it matched what I was trying to send, but it seemed that the first bit was not in sync with the clock so I believe the chip is not getting the correct binary byte. I searched around and found articles on how to use the chip with I2C, but can't seem to figure out how to use it with SPI. I am using a MMC5983MA-B breakout board to make things easier (data sheet linked below).
MMC5983MA:
MMC983MA-B:
Here is the code that I am using:
#include <SPI.h>
const byte READ = 0b11000000;
const byte WRITE = 0b00000000;
#define XOUT_0 0x00
#define XOUT_1 0x01
#define YOUT_0 0x02
#define YOUT_1 0x03
#define ZOUT_0 0x04
#define ZOUT_1 0x05
#define XYZOUT_2 0x06
#define TOUT 0x07
#define STATUS 0x08
#define CONTROL_0 0x09
#define CONTROL_1 0x0A
#define CONTROL_2 0x0B
#define CONTROL_3 0x0C
#define PRODUCT_ID 0x2F
const int chipSelectPin = 23;
bool configured = false;
// Initialize pins
pinMode(chipSelectPin, OUTPUT);
// Start SPI Library
SPI.begin();
// Setup SPI communication
SPI.beginTransaction(SPISettings(10000000, MSBFIRST, SPI_MODE3));
// Configure chip
if (configured == false){
writeRegister(CONTROL_1, 0b10000000); // Reset chip and set bandwidth to 8ms, 100Hz
writeRegister(CONTROL_2, 0b00001010); // Enable continuous measurement and set frequency to 10Hz
Serial.println("Configured");
configured = true;
// Allow sensor time to setup
delay(100);
// Attempt to read Product ID
int data = readRegister(PRODUCT_ID, 1);
Serial.print("I AM "); Serial.print(data); Serial.print(" I should be "); Serial.println(0x30, HEX);
//Serial.println(data,BIN);
// SPI.endTransaction();
// Read from MMC5983MA
unsigned int readRegister(byte thisRegister, int bytesToRead){
unsigned int result = 0; // result to return
// Combine register and binary read command
byte dataToSend = thisRegister | READ;
// Select chip by setting pin low
digitalWrite(chipSelectPin, LOW);
// Print to serial what due is sending
Serial.print("Sending: "); Serial.println(dataToSend, BIN);
// Send the chip the register to read
SPI.transfer(dataToSend);
// Send 0 to read response
result = SPI.transfer(0x00);
// Deselect the chip
digitalWrite(chipSelectPin, HIGH);
return (result);
void writeRegister(byte thisRegister, byte thisValue){
// Combine register with write byte
byte dataToSend = thisRegister | WRITE;
// Select chip
// Send register
// Send value to record in register
SPI.transfer(thisValue);
No matter what address I send to read, I get 255 in binary (11111111). I have double checked my wiring and had a lab mate double check it as well. I have tried configuring the chip in both the setup and the loop. Not sure what the issue is. Any help would be greatly appreciated.
Thank you so much,
Trevor
