here is the full error message:
sketch_nov16a:12:173: error: use of deleted function 'MoToStepper::MoToStepper(MoToStepper&&)'
MoToStepper mysteppers[] = {(stepsPerRev, STEPDIR), (stepsPerRev, STEPDIR), (stepsPerRev, STEPDIR), (stepsPerRev, STEPDIR), (stepsPerRev, STEPDIR), (stepsPerRev, STEPDIR)};
In file included from C:\arduino-nightly\libraries\MobaTools-master\src/MobaTools.h:170:0,
from C:\Users\A-A-F\AppData\Local\Temp\arduino_modified_sketch_133755\sketch_nov16a.ino:4:
C:\arduino-nightly\libraries\MobaTools-master\src/utilities/MoToStepper.h:142:5: note: declared here
MoToStepper (MoToStepper && ) =delete;
C:\arduino-nightly\libraries\MobaTools-master\src/utilities/MoToStepper.h:145:5: note: after user-defined conversion: MoToStepper::MoToStepper(long int)
MoToStepper(long steps); // steps per 360 degree in HALFSTEP mode or A4988 Mode on ESP
C:\Users\A-A-F\AppData\Local\Temp\arduino_modified_sketch_133755\sketch_nov16a.ino: In function 'void setup()':
sketch_nov16a:17:18: error: base operand of '->' has non-pointer type 'MoToStepper'
mysteppers[i]->attach( stepPin[i], dirPin[i] );
sketch_nov16a:18:18: error: base operand of '->' has non-pointer type 'MoToStepper'
mysteppers[i]->setSpeed ( 1400 );
sketch_nov16a:19:18: error: base operand of '->' has non-pointer type 'MoToStepper'
mysteppers[i]->setRampLen( stepsPerRev / 2);
sketch_nov16a:22:16: error: base operand of '->' has non-pointer type 'MoToStepper'
mysteppers[3]->doSteps(400); //rotate the element number 3, which corresponds to pins 5 and 11
sketch_nov16a:23:16: error: base operand of '->' has non-pointer type 'MoToStepper'
mysteppers[4]->doSteps(400);
Using library MobaTools-master at version 2.4.3 in folder: C:\arduino-nightly\libraries\MobaTools-master
exit status 1
