i want check mobile Battery % with Arduino Host USB how can it possible.?
Hello nahush
Welcome to the best Arduino forum ever ![]()
Yes, it is.
Choose an Arduino board that supports a USB connection and then design and program a sketch for your project.
Mayby, it depends on your circuit and code. Are you trying to make a state of charge indicator? Is the battery directly connected to the USB? Post an annotated schematic showing how you expect to wire this.
USB is generally powered with 5V from a voltage regulator, You will not get any information from that 5V source.
Thanks. I am loooking for Bluetooth App & app thrue control mobile battery charge connect with PD
What is this Host USB of which you speak? Host implies that is trying to act as a USB host do you really mean that?
Do you mean Pure Data when you say PD. The graphic programming language for music and sound generation.
I can't see how that would possibly work.
PD mean power delivered. Host mean Ready mead arduino board came with usb
Maybe you mean Ready made, as mead is a drink containing fermented honey.
Well I don't understand that word either. So maybe I will give this post a miss.
Good luck with your project.
i have less know USB host Arduino mean
Help explain your meaning by making a well-labeled drawing with all the devices involved.
Probably best to type full details in your native language into Google Translate and then copy the result here.
Dear
no need to go further for same case please
Incomprehensible. Use translator web site.
