UPDATE: Changed shortPressed() to just pressed and it seems to have fixed the problem but I really don't understand why......
Still super new to this. I have a set of 4 buttons and a switch (gnd or vcc). The switch selects which set of buttons can be used. I'm checking the switch using buttons.state(SW) and it it's low then buttons A and B are active and I'm using state on those to see if they are being pressed and held in (moving a stepper) When the switch is HIGH, buttons C and D are active and they start or stop an automatic cycle of the stepper (back and forth) I've got it more or less working right, the buttons work as they should and only the active ones work when the switch is in whichever state BUT if the switch is set to A/B and I press button C or D, nothing happens.... until I flip the switch to the automatic cycle position and it seems to have remembered that button C or D was pressed before and the automatic cycle starts instantly... Or at least that's what it looks to be doing. If I don't touch C or D I can switch back and forth without issue but if I press one while it's in manual mode it starts a cycle as soon as the switch is flipped over. Related Code:
#define MAX8BUTTONS // This saves ressources if you don't need more than 8 buttons
#include <MobaTools.h>
/* eps32 test code */
const byte buttonPins [] = { 13,16,17,18, 19 };
enum : byte {SW_SEL, MAN_UP, MAN_DOWN, AUT_START, AUT_STOP };
const byte buttonCount = sizeof(buttonPins);
MoToButtons Buttons( buttonPins, buttonCount, 20, 500 ); // 500ms to distinguish short/long
//const int SEL_SW = 13; // Manual / auto select switch
//const int MAN_UP = 16; // Stepper Manual Up button
//const int MAN_DN = 17; // Stepper Manual Down Button
//const int AUT_START = 18; // Auto Start Button
//const int AUT_STOP = 19; // Auto Stop Button
const int HOME_SW = 33; // upper home switch
const int DIR = 2; // Stepper DIR Pin 2
const int STEP = 4; // Stepper STEP Pin 4
const int SPEED_IN = 32; // Analog Input
//const int CYCLES_IN = xx; // Analog Input
//const int DWELL_IN = xx; // Analog Input
bool isStepping = false;
bool home_state = 0;
bool MAN_UP_STATE = LOW;
bool MAN_UP_PREV = LOW;
bool MAN_DN_STATE = LOW;
bool MAN_DN_PREV = LOW;
bool AUT_START_STATE = LOW;
//int DWELL_DATA = 0;
//int DWELL = 0;
//int Start_Time = 0;
//int Stop_Time = 0;
int Cycle_To_Do = 0;
int cycle_cnt=0;
long maxSpeed = 20000;
int ramp_len=500;
bool HOMED = false;
// ballscrew is 5mm pitch
const long EndPoint = 36576; //52832 = 26" 36576 = 18" 24384 = 12"
long nextPos = 0;
MoToStepper myStepper (400,STEPDIR); // setps per rev and what type of control
// pinMode(AUT_START,INPUT_PULLUP);
// pinMode(AUT_STOP,INPUT_PULLUP);
// pinMode(MAN_UP,INPUT_PULLUP);
// pinMode(MAN_DN,INPUT_PULLUP);
pinMode(HOME_SW,INPUT_PULLUP);
myStepper.attach( STEP, DIR ); //4, 2
myStepper.setSpeed( maxSpeed );
myStepper.setRampLen(400); //400
delay(2000); // need to prevent partial run when loading
Cycle_To_Do=2; // this will come from selector switch CYCLES_IN
// ***** HOMING THE CARRIGE *****
myStepper.setZero(0); //
myStepper.setSpeed( 5000 ); // slow speed for homing
myStepper.moveTo(3000); // move the carrige down some
while ( myStepper.distanceToGo()!=0 )
Serial.println("Staging");
while (HOMED == false ) // move up to home switch
Serial.println("Homing");
home_state = digitalRead(HOME_SW); // Check the switch
// It was not working
// correctly when I used
// if (digitalRead(HOME_SW) == 0)
// but the switch was buggy
// so maybe ok now that its fixed
myStepper.moveTo(myStepper.currentPosition()-400); // keep moving up
if (home_state==0)
myStepper.stop();
myStepper.setZero(1200); // come down off the switch
myStepper.moveTo(0);
HOMED=true;
Serial.println("SOFT");
Serial.println("HOMED");
//if (myStepper.distanceToGo()==0 && HOMED == true)
// myStepper.setSpeed(maxSpeed); // Set full speed
// Serial.println("HOMED");
Buttons.processButtons();
if(Buttons.state(SW_SEL)) //****************** manual mode ***********
if(Buttons.state(MAN_UP))
Serial.println("UP button pressed");
if (myStepper.currentPosition()-400 >0)
myStepper.moveTo(myStepper.currentPosition() - 400);
if(digitalRead(HOME_SW)==false)
myStepper.stop();
Serial.println("LIMIT");
else if(Buttons.state(MAN_DOWN))
myStepper.moveTo(myStepper.currentPosition() + 500);
Serial.println("DOWN button pressed");
else //************************ automnatic mode **************************
if( !isStepping ) // not currently cycling
if ( Buttons.shortPress(AUT_START) )
// if(digitalRead(AUT_START)==false) // check for start button press
Serial.println("START button pressed");
isStepping = true;
myStepper.moveTo(EndPoint);
else // is running cycles
if ( myStepper.distanceToGo()==0 ) // reached target
if(myStepper.currentPosition() == EndPoint) // if it's at the bottom
myStepper.moveTo(0); // new target at the top
else // it's at the top
myStepper.moveTo(EndPoint); // new targer at the bottom
cycle_cnt++; // count the # of cycles
// if it's at the top
// and had done the # of
// cycles needed
if( cycle_cnt>=Cycle_To_Do && myStepper.currentPosition() == 0)
myStepper.stop();
isStepping = false;
cycle_cnt=0;
Serial.println("done");
else // moving between end points
if ( Buttons.shortPress(AUT_STOP) )
//if(digitalRead(AUT_STOP)==false) // check the stop button
Serial.println("STOP button pressed");
myStepper.setSpeed(0); // stop with ramp
// stepperPause.setTime( 1000 ); // not sure if needed
myStepper.setSpeed(maxSpeed); // reset speed
myStepper.moveTo(0); // go back to the up position
cycle_cnt=Cycle_To_Do; // cancel any outstanding cycles
isStepping = false;
I would have thought the Press of the AUT_START while SW_SEL was low would be wiped out next time through the loop where it was no longer pressed but apparently not.
