[MOD] Arduino Enhanced Release 1.0.5 for Windows (installer, drivers, etc) +SRC
In this package the GUID I used is:
8220E838-DFF3-45AA-B338-EC34684489EA
And I will use that one forever. :)
Thanks for the info, I'm on my laptop so can't check the key I was writing to exactly, but basically I was storing the arduino IDE version as the key and the exectable path for arduino.exe for that version
"Registry Key"/Arduino/Version/1.0.1.0 ExePath "C:\ProgramFiles\Arduino1.0.1
My applications need to be able to scroll through all versions of installed arduino so a key is created for each install as above.
michaelcollier:
Thanks for the info, I’m on my laptop so can’t check the key I was writing to exactly, but basically I was storing the arduino IDE version as the key and the exectable path for arduino.exe for that version
“Registry Key”/Arduino/Version/1.0.1.0 ExePath "C:\ProgramFiles\Arduino1.0.1
Well, I am not particulary fan of adding things to registry. In fact I haven’t added anything in the setup extra to any directory or registry rater than the ultra-required one, like unninstaller.
I am sure that you have more than enough info in the registry to autodetect last version XD
Thanks for the screenshot, I need all installed versions not just the latest, when you run your setup for the next version of Arduino (maybe 1.0.1.a or something) will it produce a second set of data as per the first screenshot, or will it overwrite that information? If it produces a second set of data for 1.0.1.a then that should be ok for me. I can see why you would want to avoid writing to the registry, it is not something I do often myself.
Sorry, you are already on 1.0.1.a so please apply the previous question to 1.0.1.b (I am 1 version behind you)
michaelcollier: Thanks for the screenshot, I need all installed versions not just the latest, when you run your setup for the next version of Arduino (maybe 1.0.1.a or something) will it produce a second set of data as per the first screenshot, or will it overwrite that information? If it produces a second set of data for 1.0.1.a then that should be ok for me. I can see why you would want to avoid writing to the registry, it is not something I do often myself.
Yes, it is always updated to last version. In fact most apps you can find do this (or the app itself keeps the HKCU structure updated on every run).
OK thanks, I'll have to stick with what I have for the moment then, my application needs to be able to scroll through all Arduino versions and directories, users need to be able to install older Arduino versions alongside newer versions, so overwriting the current installation info won't work for me but would be fine for everyone else I guess, cheers, Mike
Updated today!
New shiny WINAVR, please test it ;) I only have MEGA and Uno but all my sketches are compiling and getting smaller sizes :D
Where is the "New Code" the "New shiny WINAVR"... I downloaded the Aug 13 version...
Doc
Docedison: Where is the "New Code" the "New shiny WINAVR"... I downloaded the Aug 13 version...
Doc
Below big red download text in the first message.
Hello! I am working on a library installer now! for the manager, it looks like this:
It can install compressed libraries and uncompressed ones:
If the library is not on the first folder (for example if there are other subfolders or files), it will look for it inside and even fix the name to match Arduino library guidelines:
And if the library is old, it will try to fix it:
Any comments or suggestions will be appreciated :)
Some ideas:
  1. baudrate checker (baudrate vs. crystal frequency with an brate error, ie “8MHz and 115k2 used - error of 7.8% !”)
  2. pin assignment checker (ie you’ll get a window with actual pin assignment with input/outputs and pin names indication coming from the source, maybe with possible collisions based on the board used - ie “wrong Sdcard SPI pins used”, “wrong I2C pins used”)
  3. something more complex - for DIY boards - an automatic system for DIY_board_name<->arduino_pin<->atmega_chip_pin management (ie for easy creation of your own variants with some checks)
    :slight_smile:
    Chips supported: atmega32, atmega328p, atmega1284p (both 44pin smt and dil40), atmega128, atmega1280, atmega2560.
pito:
Some ideas:
    :slight_smile:
  1. Sounds nice, like a board manager right? (Duplicate, Delete, edit)
    I don’t quite undestand the first 2 ones, but if you can explain a bit more where to get that data I will understand
mega spot on
a windows installer was sadly missing, makes arduino much easier to install for the new bee that arduino is aimed at.
have not tried (c) yet, but the memory free check is a great add on, as is the lib manager. all should be in the 'full' arduino path / set up me thinks,
( is anyone listening ? )
drjiohnsmith: have not tried (c) yet, but the memory free check is a great add on, as is the lib manager.****** all should be in the 'full' arduino path / set up me thinks,
What do you mean? where the library manager do his things?
****** don't forget the driver installer for novices :D
Hi
in my bad english I was trying to say well done,
the lib manager I had not seen till your (c) release, and the installer is great,
( any chance of an uninstaller to complete the process )
Yes, unninstaller sounds nice, but I am not sure if is just better to disable a library rather than unninstalling it. I have to test more because the "Add" option is still under testings mainly because the "Update old library" procedure must work very well otherwise I will not enable that feature.
I'd like a toggle "switch" to open terminal after upload. I use the shortcut Ctrl+U to upload the sketches, and I want a way to (optionally) automatically open the terminal.
mattallen37: I'd like a toggle "switch" to open terminal after upload. I use the shortcut Ctrl+U to upload the sketches, and I want a way to (optionally) automatically open the terminal.
Which shortcut is free?
In file menu there is a new menu to upload and open serial monitor, also you can press CTRL+upload
Instead of a shortcut, I would like it to be a toggle option. If you want it to be a shortcut though, Alt+U should be fine.
Either that, or else a shortcut that opens the terminal (not upload and open the terminal, just open the terminal), but if the program is uploading, it wait's till it finishes.
