I am trying to programind and trying to communicate arduino and HMI screen (Easy wiev)
when I write from SCADA as 500 led pin 13 must blinking
#include <ModbusMaster.h>
int led = 13;
ModbusMaster node(2);
node.begin(19200);
static uint32_t i;
uint8_t j, result;
uint16_t data[6];
i++;
// set word 0 of TX buffer to least-significant word of counter (bits 15..0)
node.setTransmitBuffer(0, lowWord(i));
// set word 1 of TX buffer to most-significant word of counter (bits 31..16)
node.setTransmitBuffer(1, highWord(i));
// slave: write TX buffer to (2) 16-bit registers starting at register 0
result = node.writeMultipleRegisters(0, 2);
// slave: read (6) 16-bit registers starting at register 2 to RX buffer
result = node.readHoldingRegisters(2, 6);
// do something with data if read is successful
if (result == node.ku8MBSuccess)
for (j = 0; j < 6; j++)
data[j] = node.getResponseBuffer(j);
if(word(2)==200)
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
is this correct one if not please somebody tell me how it is possible
