modbus comm between arduino and PLC
i am a student from india and i am trying to communicate PLC(allen bradely make with ARDUINO i am doing it using modbus protocol
i want to control PLC using arduino so i made PLC as a modbus rtu slave and my arduino as a modbus rtu master
now i want to implent the read the input from PLC using arduino and also want to write coil using arduino as it is a master
i am using the modbus master library which i have copied below now how to read the discrete input and how to writre the coil to the PLC PLEASE HELP ME as i am very new to arduino i have also attached how i have make PLC as modbus rtu slave
//PhoenixContact_nanoLC.pde - example using ModbusMaster library
to communicate with PHOENIX CONTACT nanoLine controller.
This file is part of ModbusMaster.
ModbusMaster is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
ModbusMaster is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with ModbusMaster. If not, see http://www.gnu.org/licenses/.
Written by Doc Walker (Rx)
Copyright ? 2009, 2010 Doc Walker
$Id: PhoenixContact_nanoLC.pde 39 2010-02-10 02:12:21Z dfwmountaineers $
#include <ModbusMaster.h>
// discrete coils
#define NANO_DO(n) (0x0000 + n) ///< returns nanoLC discrete output address
#define NANO_FLAG(n) (0x1000 + n) ///< returns nanoLC flag address
// discrete inputs
#define NANO_DI(n) (0x0000 + n) ///< returns nanoLC discrete input address
// analog holding registers
#define NANO_REG(n) (0x0000 + 2 * n) ///< returns nanoLC holding register address
#define NANO_AO(n) (0x1000 + 2 * n) ///< returns nanoLC analog output address
#define NANO_TCP(n) (0x2000 + 2 * n) ///< returns nanoLC timer/counter preset address
#define NANO_OTP(n) (0x3000 + 2 * n) ///< returns nanoLC discrete output preset address
#define NANO_HSP(n) (0x4000 + 2 * n) ///< returns nanoLC high-speed counter preset address
#define NANO_TCA(n) (0x5000 + 2 * n) ///< returns nanoLC timer/counter accumulator address
#define NANO_OTA(n) (0x6000 + 2 * n) ///< returns nanoLC discrete output accumulator address
#define NANO_HSA(n) (0x7000 + 2 * n) ///< returns nanoLC high-speed counter accumulator address
// analog input registers
#define NANO_AI(n) (0x0000 + 2 * n) ///< returns nanoLC analog input address
// instantiate ModbusMaster object, serial port 0, Modbus slave ID 1
ModbusMaster nanoLC(0, 1);
// initialize Modbus communication baud rate
nanoLC.begin(19200);
static uint32_t u32ShiftRegister;
static uint32_t i;
uint8_t u8Status;
u32ShiftRegister = ((u32ShiftRegister < 0x01000000) ? (u32ShiftRegister << 4) : 1);
if (u32ShiftRegister == 0) u32ShiftRegister = 1;
i++;
// set word 0 of TX buffer to least-significant word of u32ShiftRegister (bits 15..0)
nanoLC.setTransmitBuffer(0, lowWord(u32ShiftRegister));
// set word 1 of TX buffer to most-significant word of u32ShiftRegister (bits 31..16)
nanoLC.setTransmitBuffer(1, highWord(u32ShiftRegister));
// set word 2 of TX buffer to least-significant word of i (bits 15..0)
nanoLC.setTransmitBuffer(2, lowWord(i));
// set word 3 of TX buffer to most-significant word of i (bits 31..16)
nanoLC.setTransmitBuffer(3, highWord(i));
// write TX buffer to (4) 16-bit registers starting at NANO_REG(1)
// read (4) 16-bit registers starting at NANO_REG(0) to RX buffer
// data is available via nanoLC.getResponseBuffer(0..3)
nanoLC.readWriteMultipleRegisters(NANO_REG(0), 4, NANO_REG(1), 4);
// write lowWord(u32ShiftRegister) to single 16-bit register starting at NANO_REG(3)
nanoLC.writeSingleRegister(NANO_REG(3), lowWord(u32ShiftRegister));
// write highWord(u32ShiftRegister) to single 16-bit register starting at NANO_REG(3) + 1
nanoLC.writeSingleRegister(NANO_REG(3) + 1, highWord(u32ShiftRegister));
// set word 0 of TX buffer to nanoLC.getResponseBuffer(0) (bits 15..0)
nanoLC.setTransmitBuffer(0, nanoLC.getResponseBuffer(0));
// set word 1 of TX buffer to nanoLC.getResponseBuffer(1) (bits 31..16)
nanoLC.setTransmitBuffer(1, nanoLC.getResponseBuffer(1));
// write TX buffer to (2) 16-bit registers starting at NANO_REG(4)
nanoLC.writeMultipleRegisters(NANO_REG(4), 2);
// read 17 coils starting at NANO_FLAG(0) to RX buffer
// bits 15..0 are available via nanoLC.getResponseBuffer(0)
// bit 16 is available via zero-padded nanoLC.getResponseBuffer(1)
nanoLC.readCoils(NANO_FLAG(0), 17);
// read (66) 16-bit registers starting at NANO_REG(0) to RX buffer
// generates Modbus exception ku8MBIllegalDataAddress (0x02)
u8Status = nanoLC.readHoldingRegisters(NANO_REG(0), 66);
if (u8Status == nanoLC.ku8MBIllegalDataAddress)
// read (64) 16-bit registers starting at NANO_REG(0) to RX buffer
// data is available via nanoLC.getResponseBuffer(0..63)
u8Status = nanoLC.readHoldingRegisters(NANO_REG(0), 64);
// read (8) 16-bit registers starting at NANO_AO(0) to RX buffer
// data is available via nanoLC.getResponseBuffer(0..7)
nanoLC.readHoldingRegisters(NANO_AO(0), 8);
// read (64) 16-bit registers starting at NANO_TCP(0) to RX buffer
nanoLC.readHoldingRegisters(NANO_TCP(0), 64);
// read (64) 16-bit registers starting at NANO_OTP(0) to RX buffer
nanoLC.readHoldingRegisters(NANO_OTP(0), 64);
// read (64) 16-bit registers starting at NANO_TCA(0) to RX buffer
nanoLC.readHoldingRegisters(NANO_TCA(0), 64);
// read (64) 16-bit registers starting at NANO_OTA(0) to RX buffer
nanoLC.readHoldingRegisters(NANO_OTA(0), 64);
// read (8) 16-bit registers starting at NANO_AI(0) to RX buffer
nanoLC.readInputRegisters(NANO_AI(0), 8);
