Good day. I am using the following code. When i run the code and connect the arduino to the remote. It does not work. i looked into the serial monitor and noticed the program did not start. Can someone maybe assist?
#include <SPI.h>
#include <Ethernet.h> // Ethernet library v2 is required
#include <ModbusEthernet.h>
#include <MPU6050_tockn.h>
#include <Wire.h>
MPU6050 mpu6050(Wire);
const uint16_t REG1 = 57344; // Heading Hreg Offset
const uint16_t REG2 = 57346; // Trigger Hreg Offset
const uint16_t REG3 = 57348; // Dirtection Hreg Offset
const uint16_t REG4 = 57350; // Speed Hreg Offset
float float3 = 0;
int OldAngle = 0;
int NewAngle = 0;
// Set IP for VibGuard //
IPAddress remote(10, 196, 214, 219);
const int32_t showDelay = 1000; // Show result every n'th mellisecond
// Enter a MAC address and IP address for your controller below.
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEE
// Set IMU IP //
IPAddress ip(10, 196, 214, 220); // The IP address will be dependent on your local network:
ModbusEthernet mb; // Declare ModbusTCP instance
Serial.begin(115200); // Open serial communications and wait for port to open
//#if defined(AVR_LEONARDO)
//while (!Serial) {} // wait for serial port to connect. Needed for Leonardo only
//#endif
Ethernet.init(10); // SS pin
Ethernet.begin(mac, ip); // start the Ethernet connection
delay(1000); // give the Ethernet shield a second to initialize
mb.client(); // Act as Modbus TCP server
Wire.begin();
mpu6050.begin();
mpu6050.calcGyroOffsets(true);
uint16_t res1 = 0; //Heading
uint16_t res2 = 1; //Trigger
uint16_t res3 = 0; //Direction
uint16_t res4 = 0; //speed
uint32_t showLast = 0; int mult = 0;
if (mb.isConnected(remote)) { // Check if connection to Modbus Slave is established
mpu6050.update();
float float2 = float(mpu6050.getAngleZ() * -1);
int Angle = (uint16_t) float2;
float float4 = float(mpu6050.getGyroZ());
int AccZ = (uint16_t) float4;
//Heading Multiplier
mult = float2 / 360;
if (mult < 0) {
mult = mult * -1;
if (float2 > 0)
float3 = float2 - (mult * 360);
if ((float2 < 0) && (float2 > (-1 * 360)))
float3 = float2 - (mult * 360) + 360;
if ((float2 < 0) && (float2 < -(1 * 360)))
float3 = ((((float2 + (mult * 360)) * -1) - 360) * -1);
NewAngle = float3;
uint16_t res1 = float3; //Heading
uint16_t res4 = float4; //Speed
mb.writeHreg(remote, REG1, &res1); // Initiate Read Hreg from Modbus Slav
//Direction
if ( float4 > 1) {
mb.writeHreg(remote, REG3, &res2);
if ( float4 < -1) {
mb.writeHreg(remote, REG3, &res3);
// if (OldAngle = NewAngle){
// mult = 0;
Trigger
if(mult >= 2){
mb.writeHreg(remote, REG2, &res2 );
if(mult < 2){
mb.writeHreg(remote, REG2, &res3 );
Sprrd GyroZ
mb.writeHreg(remote, REG4, &res4);
Serial.print(mult);
Serial.print(" ");
Serial.print(float2);
Serial.print(" ");
Serial.print(float3);
Serial.print(" ");
Serial.print(float4);
Serial.print(" ");
Serial.println(res4);
mb.connect(remote); // Try to connect if not connected
mb.task(); // Common local Modbus task
delay(100);
if (millis() - showLast > showDelay) { // Display register value every 5 seconds (with default settings)
showLast = millis();
I am using a Waveshare 10D Imu sensor with a W5100 ethernet shield and arduino nano. If i remove or // the if (mb isConnected(remote)) and the else mb.connect(remote) at the bottom then the program start. I have also Serial.println and noticed the error is on the modbus side. Dont know what is the cause or how to resolve.
Thank you
