I'm not quite sure if I understand; there are already 2 ints (by the looks of it; in the regs); why convert to float and next back to int?
Can't you directly use those values in the regs?
I also have a bit of a doubt about your conversion but I can't pinpoint it. The below code prints OVF for the num variable. The numbers for the regs are based on the original float 123.45.
union X
float f;
unsigned int i[2];
unsigned char b[4];
X x;
x.f = 123.45;
// display 123.45 as its components (two ints, 4 bytes)
Serial.println(x.i[0], HEX);
Serial.println(x.i[1], HEX);
Serial.println(x.b[0], HEX);
Serial.println(x.b[1], HEX);
Serial.println(x.b[2], HEX);
Serial.println(x.b[3], HEX);
int regs[] = {0xE666, 0x42F6}; // represents 123.45
// make sure it's cleared to prevent possible confusion
x.i[0] = x.i[1] = 0;
Serial.println(x.f, 8); // prints 0.00000000
// copy the regs to the enum
x.i[0] = regs[0];
x.i[1] = regs[1];
// and check the result
Serial.println(x.f, 8); // prints 123.44999694
float num;
unsigned long temp = (unsigned long)regs[0] << 16 | regs[1];
num = *(float*)&temp;
Serial.println(num, 8); // prints ovf
I need to do this because i have to trasmit float value over serial modbus and read the incoming floats. Modbus has registers of integers, because of that you need to union 2 registers.
