Can anybody recommend a Modbus/TCP library compatible with Arduino Zero?
Thanks
Thanks
ArduinoModbus, written for the MKR series but that's almost the same hardware. Available in the Library Manager.
Thanks... I ve already tried that but examples wont compile for zero
Probably need to make changes to the libraries but i was trying to avoid that..
In file included from D:\Dropbox\MCU\Controller_Firmware\libraries\ArduinoRS485\src\RS485.cpp:20:0:
D:\Dropbox\MCU\Controller_Firmware\libraries\ArduinoRS485\src\RS485.h:35:30: error: 'A6' was not declared in this scope
#define RS485_DEFAULT_DE_PIN A6
D:\Dropbox\MCU\Controller_Firmware\libraries\ArduinoRS485\src\RS485.cpp:189:62: note: in expansion of macro 'RS485_DEFAULT_DE_PIN'
RS485Class RS485(SERIAL_PORT_HARDWARE, RS485_DEFAULT_TX_PIN, RS485_DEFAULT_DE_PIN, RS485_DEFAULT_RE_PIN);
D:\Dropbox\MCU\Controller_Firmware\libraries\ArduinoRS485\src\RS485.h:35:30: note: suggested alternative: 'A5'
Multiple libraries were found for "Ethernet.h"
Used: D:\Dropbox\MCU\Controller_Firmware\libraries\Ethernet
Not used: C:\Program Files (x86)\Arduino\libraries\Ethernet
Using library SPI at version 1.0 in folder: C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.12\libraries\SPI
Using library Ethernet at version 2.0.0 in folder: D:\Dropbox\MCU\Controller_Firmware\libraries\Ethernet
Using library ArduinoRS485 at version 1.0.2 in folder: D:\Dropbox\MCU\Controller_Firmware\libraries\ArduinoRS485
Using library ArduinoModbus at version 1.0.6 in folder: D:\Dropbox\MCU\Controller_Firmware\libraries\ArduinoModbus
exit status 1
Error compiling for board Arduino Zero (Native USB Port).
Unfortunately the library isn't written with portability in mind, so you have to modify one line in ArduinoRS485.h:
should become
#define RS485_DEFAULT_DE_PIN A5
After that change the example should compile.
Another part of the output is probably more dangerous:
You should ensure that the Arduino version of Ethernet.h is used.
Thanks very much!
I had developed my own modbus interrogation code but it periodically crushed so I decided to try a ready made library.
