im tryig to communicate with my power meter over modbus via rs485, im able to send successful modbus frame from my arduino even my meter is responding with data(im checking this using an usb rs485 connected parallely(tapped on th a and b lines of arduino and meter) but im always getting a time out error no matter what. my data is being sent by the meter immediately and the default time out is 2s , its not even taking that long, tried switching re and de pins high and low out of library but still no success.i tried for days without sleep, finally fed up and posting here any help would save me. thank you.
Hi Dharani123,
As far as I understand (If I didn't miss understand) you have no MODBUS implementation in your Arduino code.
MODBUS is a second layer protocol which works over the first layer (RS485). To able to communicate, you have to implement the MODBUS protocol, in Arduino side as well. You have to set a MODBUS address for Arduino, and power meter should communicate with that defined MODBUS address. I am sure there will be MODBUS implementation for Arduino somewhere in internet. It will be helpful also if you read about MODBUS protocol. It is a simple protocol.
You did a good job with the code, it looks like it should work but we just don’t know enough about the remainder of your installation to help. A few questions:
Which Arduino board?
A schematic of the connections of the Arduino to rs-485 module
A link to the manual of your power meter which describes its Modbus interface
the modbus inititalization. i think i dont have any issues with the modbus initialization because im able to verify that the modbus frame is correct fom the sender and my meter is also responding (please correct me if im wrong)
sender modbus frame:
01 04 00 05 00 04 E1 C8
received modbus frame
01 04 08 00 00 01 3A D5 92 26 FF 3E 18
My problem is that its giving me a timeout response without capturing result even when the meter is giving response
and yes my arduino on serial port 0 is giving 226 timeout error i dont know why its not taking response from the meter, the default time out is 2 seconds in the library and the reply is immediate. so i dont know why its giving me time out even when the meter is responding.
Thank you so much ismail thats a really useful link.
If thats a valid response then why am i not able to parse it, why is the library throwing timeout error?
The response from Power meter seems to be valid. Your requested first word is zero, second 0x013A (314), third 0xD592 (54674) and forth 0x26FF (9983).
You need to know what do those values mean in your power meter.
i can process them to their data type(64 bit integers) once i can parse the data, my poblem is that the library is not pushing this data to getresponsebuffer ,instead its giving me a time out error
Hi Dharani,
As far as I understand, you are able to send the data via modbus from Arduino, but in your Arduino code, you can not catch the data which is answered by power meter. Have you investigated the application examples of your Modbus library? Normally an interrupt driven trigger starts the reading process. I am not sure whether your problem related to interrupt triggering, but you can investigate the issue. If reading data comes to Arduino serial bus, an interrupt must be started and the data should be taken into your input array. I think all this mechanism is defined in your Modbus library. Be sure that that the related interrupt configured rightly. For example if you change the default data ports in library, you must change the interrupt sources accordingly as well. (This is just a suggestion, I am not sure whether this is the reason of your problem)
I still haven't seen a wiring diagram. It looks like a hardware problem. Either a problem with DE/RE or the wire going to the RX pin on your Arduino. Check the wires!
We need links to the used hardware (RS-485 board)!
That cannot work. Either your above code is consuming the serial traffic or the Modbus library but no both.
If the meter is indeed responding to the command, the likely problem is the RE pin is not being pulled low to enable the max485 receiver.
If the above does not help, please post photos of the board and the wiring to the Mega. We did ask earlier for a schematic which was not provided, only a block diagram which did not provide the required detail.
