MODBUS Protocol Implemetation
Hello guys,
I am trying to do modbus protocol with arduino mega over RS232 using Modbusrtu.h libraray.
I first tried the sample code . But it was not working. Here is my code.
Can anyone help me too fix this problem or is there any better library available for modbus on arduino?
 *  Modbus slave example 2:
 *  The purpose of this example is to link the Arduino digital and analog
 *	pins to an external device.
 *  Recommended Modbus Master: QModbus
 *  http://qmodbus.sourceforge.net/
#include <ModbusRtu.h>
#define ID   1
Modbus slave(ID, 0, 0); // this is slave ID and RS-232 or USB-FTDI
boolean led;
int8_t state = 0;
unsigned long tempus;
// data array for modbus network sharing
uint16_t au16data[9];
 *  Setup procedure
  io_setup(); // I/O settings
  // start communication
  slave.begin( 19200 );
  tempus = millis() + 100;
  digitalWrite(13, HIGH );
 *  Loop procedure
  // poll messages
  // blink led pin on each valid message
  state = slave.poll( au16data, 9 );
  if (state > 4) {
    tempus = millis() + 50;
    digitalWrite(13, HIGH);
  if (millis() > tempus) digitalWrite(13, LOW );
  // link the Arduino pins to the Modbus array
  io_poll();
 * pin maping:
 * 2 - digital input
 * 3 - digital input
 * 4 - digital input
 * 5 - digital input
 * 6 - digital output
 * 7 - digital output
 * 8 - digital output
 * 9 - digital output
 * 10 - analog output
 * 11 - analog output
 * 14 - analog input
 * 15 - analog input
 * pin 13 is reserved to show a successful query
void io_setup() {
  // define i/o
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(13, OUTPUT);
  digitalWrite(6, LOW );
  digitalWrite(7, LOW );
  digitalWrite(8, LOW );
  digitalWrite(9, LOW );
  digitalWrite(13, HIGH ); // this is for the UNO led pin
  analogWrite(10, 0 );
  analogWrite(11, 0 );
 *  Link between the Arduino pins and the Modbus array
void io_poll() {
  // get digital inputs -> au16data[0]
  bitWrite( au16data[0], 0, digitalRead( 2 ));
  bitWrite( au16data[0], 1, digitalRead( 3 ));
  bitWrite( au16data[0], 2, digitalRead( 4 ));
  bitWrite( au16data[0], 3, digitalRead( 5 ));
  // set digital outputs -> au16data[1]
  digitalWrite( 6, bitRead( au16data[1], 0 ));
  digitalWrite( 7, bitRead( au16data[1], 1 ));
  digitalWrite( 8, bitRead( au16data[1], 2 ));
  digitalWrite( 9, bitRead( au16data[1], 3 ));
  // set analog outputs
  analogWrite( 10, au16data[2] );
  analogWrite( 11, au16data[3] );
  // read analog inputs
  au16data[4] = analogRead( 0 );
  au16data[5] = analogRead( 1 );
  // diagnose communication
  au16data[6] = slave.getInCnt();
  au16data[7] = slave.getOutCnt();
  au16data[8] = slave.getErrCnt();
[code]
[/code]
Define not working?
Time out message coming at modbus simulation
What Modbus simulation? How is the Arduino connected? What does your electrical schematic look like?
