Dear all,[
I have Modbus library . I have below code . Is there any way to software to check Master slave Configuration.How to Configure Master. Since i am new to modbus protocol . Can some tell me How to test below code.
](http://I have Modbus library . I have below code . Is there any way to software to check Master slave Configuration.How to Configure Master. Since i am new to modbus protocol . Can some tell me How to test below code.)rs485 - Arduino as Modbus client with MAX485 doesn't get any response - Electrical Engineering Stack Exchange
#include <modbus.h>
#include <modbusDevice.h>
#include <modbusRegBank.h>
#include <modbusSlave.h>
This example code shows a quick and dirty way to get an
arduino to talk to a modbus master device with a
device ID of 1 at 9600 baud.
//Setup the brewtrollers register bank
//All of the data accumulated will be stored here
modbusDevice regBank;
//Create the modbus slave protocol handler
modbusSlave slave;
//Assign the modbus device ID.
regBank.setId(1);
modbus registers follow the following format
00001-09999 Digital Outputs, A master device can read and write to these registers
10001-19999 Digital Inputs, A master device can only read the values from these registers
30001-39999 Analog Inputs, A master device can only read the values from these registers
40001-49999 Analog Outputs, A master device can read and write to these registers
Analog values are 16 bit unsigned words stored with a range of 0-32767
Digital values are stored as bytes, a zero value is OFF and any nonzer value is ON
It is best to configure registers of like type into contiguous blocks. this
allows for more efficient register lookup and and reduces the number of messages
required by the master to retrieve the data
//Add Digital Output registers 00001-00016 to the register bank
regBank.add(1);
regBank.add(2);
regBank.add(3);
regBank.add(4);
regBank.add(5);
regBank.add(6);
regBank.add(7);
regBank.add(8);
regBank.add(9);
regBank.add(10);
regBank.add(11);
regBank.add(12);
regBank.add(13);
regBank.add(14);
regBank.add(15);
regBank.add(16);
//Add Digital Input registers 10001-10008 to the register bank
regBank.add(10001);
regBank.add(10002);
regBank.add(10003);
regBank.add(10004);
regBank.add(10005);
regBank.add(10006);
regBank.add(10007);
regBank.add(10008);
//Add Analog Input registers 30001-10010 to the register bank
regBank.add(30001);
regBank.add(30002);
regBank.add(30003);
regBank.add(30004);
regBank.add(30005);
regBank.add(30006);
regBank.add(30007);
regBank.add(30008);
regBank.add(30009);
regBank.add(30010);
//Add Analog Output registers 40001-40020 to the register bank
regBank.add(40001);
regBank.add(40002);
regBank.add(40003);
regBank.add(40004);
regBank.add(40005);
regBank.add(40006);
regBank.add(40007);
regBank.add(40008);
regBank.add(40009);
regBank.add(40010);
regBank.add(40011);
regBank.add(40012);
regBank.add(40013);
regBank.add(40014);
regBank.add(40015);
regBank.add(40016);
regBank.add(40017);
regBank.add(40018);
regBank.add(40019);
regBank.add(40020);
Assign the modbus device object to the protocol handler
This is where the protocol handler will look to read and write
register data. Currently, a modbus slave protocol handler may
only have one device assigned to it.
slave._device = ®Bank;
// Initialize the serial port for coms at 9600 baud
slave.setBaud(9600);
//put some data into the registers
regBank.set(1, 1);
regBank.set(2, 1);
regBank.set(3, 0);
regBank.set(4, 1);
regBank.set(5, 1);
regBank.set(6, 0);
regBank.set(7, 1);
regBank.set(8, 0);
regBank.set(10001, 1);
regBank.set(10002, 1);
regBank.set(10003, 1);
regBank.set(10004, 1);
regBank.set(10005, 0);
regBank.set(10006, 0);
regBank.set(10007, 0);
regBank.set(10008, 0);
regBank.set(30001,1);
regBank.set(30002,2);
regBank.set(30003,3);
regBank.set(30004,4);
regBank.set(30005,5);
regBank.set(30006,6);
regBank.set(30007,7);
regBank.set(30008,8);
regBank.set(30009,9);
regBank.set(30010,10);
regBank.set(40001,1);
regBank.set(40002,2);
regBank.set(40003,2);
regBank.set(40004,4);
regBank.set(40005,5);
regBank.set(40006,6);
regBank.set(40007,7);
regBank.set(40008,8);
regBank.set(40009,9);
regBank.set(40010,10);
while(1)
//put a random number into registers 1, 10001, 30001 and 40001
regBank.set(1, (byte) random(0, 2));
regBank.set(10001, (byte) random(0, 2));
regBank.set(30001, (word) random(0, 32767));
regBank.set(40001, (word) random(0, 32767));
slave.run();
