der sketch müsste funktionieren:
Modbus Client Example 0x60 (Modbus Master)
Read EPSOLAR - all registers
This Modbus Client
- reads registers from Modbus Servers periodically
based on an idea
RS485_HalfDuplex.pde - example using ModbusMaster library to communicate
with EPSolar LS2024B controller using a half-duplex RS485 transceiver.
This example is tested against an EPSolar LS2024B solar charge controller.
See here for protocol specs:
http://www.solar-elektro.cz/data/dokumenty/1733_modbus_protocol.pdf
hardware
- a LED
- 4 push buttons
- a MAX485-TTL adapter
by noiasca
2022-07-30
Serial Interface
// if you don't have enough HW Serial (i.e. on an UNO)
// you are forced to use SoftwareSerial or AltSoftSerial
//include <SoftwareSerial.h>
//constexpr uint8_t rxPin = 2; // for Softserial
//constexpr uint8_t txPin = 3;
//SoftwareSerial mySerial(rxPin, txPin);
// On a Mega you can simply use
// a Reference to an existing HW Serial:
HardwareSerial &mySerial = Serial3;
Modbus
#include <ModbusMaster.h> // Modbus Master 2.0.0 by Doc Walker - install with Library Manager
constexpr uint8_t modbusEnablePin = 5; // The GPIO used to control the MAX485 TX pin. Set to 255 if you are not using RS485 or a selfsensing adapter
constexpr uint32_t modbusBaud = 115200; // use slow speeds with SoftSerial
constexpr uint16_t modbusRestTx = 15000; // rest time between transmissions - microseconds
uint32_t modbusPreviousTx = 0; // timestamp of last transmission - microseconds
ModbusMaster serverA; // instantiate ModbusMaster object - slave - node
// this function will be called before the client transmits data
void preTransmission()
while (micros() - modbusPreviousTx < modbusRestTx) // check last transmission end and wait if the call was to early
yield(); // wait some time and allow background tasks
digitalWrite(modbusEnablePin, HIGH);
// this function will be called after the transmission
void postTransmission()
digitalWrite(modbusEnablePin, LOW);
modbusPreviousTx = micros(); // remember last timestamp
// do all the settings for the Modbus
void modbusInit()
mySerial.begin(modbusBaud); // initialize Modbus communication baud rate
serverA.begin(1, mySerial); // communicate with Modbus server ID over the given Serial interface
pinMode(modbusEnablePin, OUTPUT); // Init enable pins for modbus master library
serverA.preTransmission(preTransmission); // Callbacks allow us to configure the RS485 transceiver correctly
serverA.postTransmission(postTransmission);
Modbus - Implementation
void requestData()
static uint32_t previousMillis = -5000; // timestamp of last request
static uint8_t actual = 0; // actual iteration
uint32_t currentMillis = millis();
if (currentMillis - previousMillis > 5000) // set the interval in ms
uint16_t reg = 0x3100;
int result;
switch (actual)
case 0 :
reg = 0x3100;
result = serverA.readInputRegisters(reg, 8);
if (result == serverA.ku8MBSuccess) // do something if read is successfull
Serial.print(F("Charging equipment input V: ")); Serial.println(serverA.getResponseBuffer(0x00) / 100.0f);
Serial.print(F("Charging equipment input A: ")); Serial.println(serverA.getResponseBuffer(0x01) / 100.0f);
Serial.print(F("Charging equipment input W: ")); Serial.println((serverA.getResponseBuffer(0x02) + ((uint32_t)serverA.getResponseBuffer(0x03) << 16)) / 100.0f); // cast and brackets
Serial.print(F("Charging equipment output V: ")); Serial.println(serverA.getResponseBuffer(0x04) / 100.0f);
Serial.print(F("Charging equipment output A: ")); Serial.println(serverA.getResponseBuffer(0x05) / 100.0f);
Serial.print(F("Charging equipment output W: ")); Serial.println((serverA.getResponseBuffer(0x06) + ((uint32_t)serverA.getResponseBuffer(0x07) << 16)) / 100.0f); // cast and brackets
Serial.print(F(" ServerA no success register ")); Serial.print(reg, HEX); Serial.print(F(" result=")); Serial.println(result, HEX);
actual++;
case 1 :
reg = 0x310C;
result = serverA.readInputRegisters(reg, 7);
Serial.print(F("Charging equipment input V: ")); Serial.println(serverA.getResponseBuffer(0x310c - reg) / 100.0f);
Serial.print(F("Charging equipment input A: ")); Serial.println(serverA.getResponseBuffer(0x310d - reg) / 100.0f);
Serial.print(F("Charging equipment input W: ")); Serial.println((serverA.getResponseBuffer(0x310e - reg) + ((uint32_t)serverA.getResponseBuffer(0x310F - reg) << 16)) / 100.0f); // cast and brackets
Serial.print(F("Battery Temperature: ")); Serial.println(serverA.getResponseBuffer(0x3110 - reg) / 100.0f);
Serial.print(F("Temperature inside equipment: ")); Serial.println(serverA.getResponseBuffer(0x3111 - reg) / 100.0f);
Serial.print(F("Power components temperature: ")); Serial.println(serverA.getResponseBuffer(0x3112 - reg) / 100.0f);
actual++;
case 2 :
reg = 0x311A;
result = serverA.readInputRegisters(reg, 2);
Serial.print(F("Battery SoC: ")); Serial.println(serverA.getResponseBuffer(0x311A - reg));
Serial.print(F("Remote battery temperature: ")); Serial.println(serverA.getResponseBuffer(0x311B - reg) / 100.0f);
actual++;
case 3 :
reg = 0x311A;
result = serverA.readInputRegisters(reg, 1);
Serial.print(F("Battery's real rated power: ")); Serial.println(serverA.getResponseBuffer(0x311D - reg) / 100.0f);
actual++;
case 4 :
reg = 0x3200;
Serial.print(F("Battery status: ")); Serial.println(serverA.getResponseBuffer(0x3200 - reg), BIN);
Serial.print(F("Charging equipment: ")); Serial.println(serverA.getResponseBuffer(0x3201 - reg), BIN);
actual++;
case 5 :
reg = 0x3300;
result = serverA.readInputRegisters(reg, 30);
Serial.print(F("Max input (PV) volt: ")); Serial.println(serverA.getResponseBuffer(0x3300 - reg) / 100.0f);
Serial.print(F("Min input (PV) volt: ")); Serial.println(serverA.getResponseBuffer(0x3301 - reg) / 100.0f);
Serial.print(F("Max battery volt: ")); Serial.println(serverA.getResponseBuffer(0x3302 - reg) / 100.0f);
Serial.print(F("Min battery volt: ")); Serial.println(serverA.getResponseBuffer(0x3303 - reg) / 100.0f);
Serial.print(F("Consumed energy today: ")); Serial.println((serverA.getResponseBuffer(0x3304 - reg) + ((uint32_t)serverA.getResponseBuffer(0x3305 - reg) << 16)) / 100.0f);
Serial.print(F("Consumed energy month: ")); Serial.println((serverA.getResponseBuffer(0x3306 - reg) + ((uint32_t)serverA.getResponseBuffer(0x3307 - reg) << 16)) / 100.0f);
Serial.print(F("Consumed energy year: ")); Serial.println((serverA.getResponseBuffer(0x3308 - reg) + ((uint32_t)serverA.getResponseBuffer(0x3309 - reg) << 16)) / 100.0f);
Serial.print(F("Total consumed: ")); Serial.println((serverA.getResponseBuffer(0x330A - reg) + ((uint32_t)serverA.getResponseBuffer(0x330B - reg) << 16)) / 100.0f);
Serial.print(F("Generated energy today: ")); Serial.println((serverA.getResponseBuffer(0x330C - reg) + ((uint32_t)serverA.getResponseBuffer(0x330D - reg) << 16)) / 100.0f);
Serial.print(F("Generated energy month: ")); Serial.println((serverA.getResponseBuffer(0x330E - reg) + ((uint32_t)serverA.getResponseBuffer(0x330F - reg) << 16)) / 100.0f);
Serial.print(F("Generated energy year: ")); Serial.println((serverA.getResponseBuffer(0x3310 - reg) + ((uint32_t)serverA.getResponseBuffer(0x3311 - reg) << 16)) / 100.0f);
Serial.print(F("Total generated energy: ")); Serial.println((serverA.getResponseBuffer(0x3312 - reg) + ((uint32_t)serverA.getResponseBuffer(0x3313 - reg) << 16)) / 100.0f);
Serial.print(F("CO2 reduction: ")); Serial.println((serverA.getResponseBuffer(0x3314 - reg) + ((uint32_t)serverA.getResponseBuffer(0x3315 - reg) << 16)) / 100.0f);
// there is one register not documented
Serial.print(F("Battery Temperature : ")); Serial.println(serverA.getResponseBuffer(0x331D - reg) / 100.0f);
Serial.print(F("Ambient Temperature : ")); Serial.println(serverA.getResponseBuffer(0x331E - reg) / 100.0f);
actual = 0; // in the last case we jump back to 0 instead of actual++;
default : actual = 0;
} // switch
// Parameters don't change so often, we only read them once after startup
// preTransmission and postTransmission take care of the requested "delay" between requests
void requestParameter()
uint16_t reg;
int result;
reg = 0x3000;
Serial.print(F("Charging equipment rated input V: ")); Serial.println(serverA.getResponseBuffer(0x00) / 100.0f);
Serial.print(F("Charging equipment rated input A: ")); Serial.println(serverA.getResponseBuffer(0x01) / 100.0f);
Serial.print(F("Charging equipment rated input W: ")); Serial.println((serverA.getResponseBuffer(0x02) + ((uint32_t)serverA.getResponseBuffer(0x03) << 16)) / 100.0f); // cast and brackets
Serial.print(F("Charging equipment rated output V:")); Serial.println(serverA.getResponseBuffer(0x04) / 100.0f);
Serial.print(F("Charging equipment rated output A:")); Serial.println(serverA.getResponseBuffer(0x05) / 100.0f);
Serial.print(F("Charging equipment rated output W:")); Serial.println((serverA.getResponseBuffer(0x06) + ((uint32_t)serverA.getResponseBuffer(0x07) << 16)) / 100.0f); // cast and brackets
Serial.print(F("Charging mode: ")); Serial.println(serverA.getResponseBuffer(0x08));
reg = 0x300E;
Serial.print(F("Rated output current of load: ")); Serial.println(serverA.getResponseBuffer(0x00) / 100.0f);
reg = 0x9000;
result = serverA.readHoldingRegisters(reg, 15);
Serial.print(F("Battery Type: ")); Serial.println(serverA.getResponseBuffer(0x9000 - reg));
Serial.print(F("Battery Capacity: ")); Serial.println(serverA.getResponseBuffer(0x9001 - reg));
Serial.print(F("Temperature compensation coeff: ")); Serial.println(serverA.getResponseBuffer(0x9002 - reg) / 100.0f);
Serial.print(F("High Volt disconnect: ")); Serial.println(serverA.getResponseBuffer(0x9003 - reg) / 100.0f);
Serial.print(F("Charging limit voltage: ")); Serial.println(serverA.getResponseBuffer(0x9004 - reg) / 100.0f);
Serial.print(F("Over voltage reconnect: ")); Serial.println(serverA.getResponseBuffer(0x9005 - reg) / 100.0f);
Serial.print(F("Equalization voltage: ")); Serial.println(serverA.getResponseBuffer(0x9006 - reg) / 100.0f);
Serial.print(F("Boost voltage: ")); Serial.println(serverA.getResponseBuffer(0x9007 - reg) / 100.0f);
Serial.print(F("Float voltage: ")); Serial.println(serverA.getResponseBuffer(0x9008 - reg) / 100.0f);
Serial.print(F("Boost reconnect voltage: ")); Serial.println(serverA.getResponseBuffer(0x9009 - reg) / 100.0f);
Serial.print(F("Low voltage reconnect: ")); Serial.println(serverA.getResponseBuffer(0x900A - reg) / 100.0f);
Serial.print(F("Under voltage recover: ")); Serial.println(serverA.getResponseBuffer(0x900B - reg) / 100.0f);
Serial.print(F("Under voltage warning: ")); Serial.println(serverA.getResponseBuffer(0x900C - reg) / 100.0f);
Serial.print(F("Low voltage disconnect: ")); Serial.println(serverA.getResponseBuffer(0x900D - reg) / 100.0f);
Serial.print(F("Discharging limit voltage recon:")); Serial.println(serverA.getResponseBuffer(0x900E - reg) / 100.0f);
reg = 0x9013;
Serial.print(F("RTC: ")); Serial.println(serverA.getResponseBuffer(0x9013 - reg));
Serial.print(F("RTC: ")); Serial.println(serverA.getResponseBuffer(0x9014 - reg));
Serial.print(F("RTC: ")); Serial.println(serverA.getResponseBuffer(0x9015 - reg));
Serial.print(F("Equalization charging cycle: ")); Serial.println(serverA.getResponseBuffer(0x9016 - reg));
Serial.print(F("Batterie Warning upper Limit: ")); Serial.println(serverA.getResponseBuffer(0x9017 - reg));
Serial.print(F("Batterie Warning upper Limit: ")); Serial.println(serverA.getResponseBuffer(0x9018 - reg));
Serial.print(F("Controller inner temperature upper limit: ")); Serial.println(serverA.getResponseBuffer(0x9019 - reg)/ 100.0f);
Serial.print(F("Controller inner temperature upper limit recover: ")); Serial.println(serverA.getResponseBuffer(0x901A - reg)/ 100.0f);
Serial.print(F("Power component temperature upper limit: ")); Serial.println(serverA.getResponseBuffer(0x901B - reg)/ 100.0f);
Serial.print(F("Power component temperature upper limit recover: ")); Serial.println(serverA.getResponseBuffer(0x901C - reg)/ 100.0f);
Serial.print(F("Line impedance: ")); Serial.println(serverA.getResponseBuffer(0x901D - reg)/ 100.0f);
Serial.print(F("Night Time Threshold Volt: ")); Serial.println(serverA.getResponseBuffer(0x901C - reg)/ 100.0f);
Serial.print(F("Light signal startup night delay:")); Serial.println(serverA.getResponseBuffer(0x901F - reg));
Serial.print(F("Day Time Threshold Volt: ")); Serial.println(serverA.getResponseBuffer(0x9020 - reg)/ 100.0f);
Serial.print(F("Light signal startup day delay: ")); Serial.println(serverA.getResponseBuffer(0x9021 - reg));
reg = 0x903D;
result = serverA.readHoldingRegisters(reg, 3);
Serial.print(F("Load controlling modes: ")); Serial.println(serverA.getResponseBuffer(0x903D - reg));
Serial.print(F("Working time length 1: ")); Serial.println(serverA.getResponseBuffer(0x903E - reg));
Serial.print(F("Working time length 2: ")); Serial.println(serverA.getResponseBuffer(0x903F - reg));
reg = 0x9042;
result = serverA.readHoldingRegisters(reg, 12);
Serial.print(F("Turn on timing 1 (sec): ")); Serial.println(serverA.getResponseBuffer(0x9042 - reg));
Serial.print(F("Turn on timing 1 (min): ")); Serial.println(serverA.getResponseBuffer(0x9043 - reg));
Serial.print(F("Turn on timing 1 (hou): ")); Serial.println(serverA.getResponseBuffer(0x9044 - reg));
Serial.print(F("Turn off timing 1 (sec): ")); Serial.println(serverA.getResponseBuffer(0x9045 - reg));
Serial.print(F("Turn off timing 1 (min): ")); Serial.println(serverA.getResponseBuffer(0x9046 - reg));
Serial.print(F("Turn off timing 1 (hou): ")); Serial.println(serverA.getResponseBuffer(0x9047 - reg));
Serial.print(F("Turn on timing 2 (sec): ")); Serial.println(serverA.getResponseBuffer(0x9048 - reg));
Serial.print(F("Turn on timing 2 (min): ")); Serial.println(serverA.getResponseBuffer(0x9049 - reg));
Serial.print(F("Turn on timing 2 (hou): ")); Serial.println(serverA.getResponseBuffer(0x904A - reg));
Serial.print(F("Turn off timing 2 (sec): ")); Serial.println(serverA.getResponseBuffer(0x904B - reg));
Serial.print(F("Turn off timing 2 (min): ")); Serial.println(serverA.getResponseBuffer(0x904C - reg));
Serial.print(F("Turn off timing 2 (hou): ")); Serial.println(serverA.getResponseBuffer(0x904D - reg));
reg = 0x9065;
result = serverA.readHoldingRegisters(reg, 1);
Serial.print(F("Length of Night: ")); Serial.println(serverA.getResponseBuffer(0x9065 - reg));
reg = 0x9067;
Serial.print(F("Battery rated voltage code: ")); Serial.println(serverA.getResponseBuffer(0x9067 - reg));
reg = 0x9069;
result = serverA.readHoldingRegisters(reg, 7);
Serial.print(F("Load timing control selection: ")); Serial.println(serverA.getResponseBuffer(0x9069 - reg));
Serial.print(F("Default load on/off: ")); Serial.println(serverA.getResponseBuffer(0x906A - reg));
Serial.print(F("Equalize Duration: ")); Serial.println(serverA.getResponseBuffer(0x906B - reg));
Serial.print(F("Boost Duration: ")); Serial.println(serverA.getResponseBuffer(0x906C - reg));
Serial.print(F("Discharge percentage: ")); Serial.println(serverA.getResponseBuffer(0x906D - reg)/100.0f);
Serial.print(F("Charging percentage: ")); Serial.println(serverA.getResponseBuffer(0x906E - reg)/100.0f);
Serial.print(F("Management Mode of battery: ")); Serial.println(serverA.getResponseBuffer(0x9070 - reg));
reg = 0x2;
result = serverA.readCoils(reg, 1);
Serial.print(F("Manual control the load: ")); Serial.println(serverA.getResponseBuffer(0x2 - reg));
reg = 0x5;
result = serverA.readCoils(reg, 2);
Serial.print(F("Enable load test mode: ")); Serial.println(serverA.getResponseBuffer(0x5 - reg));
Serial.print(F("Force the load on/off: ")); Serial.println(serverA.getResponseBuffer(0x6 - reg));
reg = 0x2000;
result = serverA.readDiscreteInputs(reg, 1);
Serial.print(F("Over temperature inside the device: ")); Serial.println(serverA.getResponseBuffer(0x2000 - reg));
reg = 0x200C;
Serial.print(F("Day/Night: ")); Serial.println(serverA.getResponseBuffer(0x200C - reg));
setup and loop
Serial.println(F("Modbus Client Example 0x60"));
modbusInit();
requestParameter();
requestData();
