system
March 19, 2014, 9:13am
1
Dear all,
I have some data to be send on SCADA system . Data like date/time. angle of motor, gps data , wind speed ,. I wanted to send the parameter through modbus protocol.Initially We use Serial.print and printing on Serial monitor or we used python to get data from Serial using (USB to TTl )level.
Now We have SCADA system, and Two arduino slaves. The scada system works on Modbus protocol. The Data has to be send from SLAVES to SCADA system via modbus protocol . Let me know how to implement modbus protocol over the Arduino Platform. How communication occur here. Please share wiring diagram for modbus protocol for arduino UNO.
system
March 19, 2014, 9:34am
2
This code i am writing RTC . Whatever value return in to RTC send to master via Modbus protocol.
Below data to be sent via modbus instead of serialmonitor
Serial.print(year);
Serial.print(month);
Serial.print(monthDay );
Serial.print(hour);
Serial.print(minute);
Serial.println(second);
#include "Wire.h"
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
void setup(){
Wire.begin();
setDateTime(); //MUST CONFIGURE IN FUNCTION
void loop(){
printDate();
void setDateTime(){
byte second = 45; //0-59
byte minute =01; //0-59
byte hour = 13; //0-23
byte weekDay =2; //1-7
byte monthDay =24; //1-31
byte month = 2; //1-12
byte year = 14; //0-99
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write(zero); //stop Oscillator
Wire.write(decToBcd(second));
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(decToBcd(weekDay));
Wire.write(decToBcd(monthDay));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.write(zero); //start
Wire.endTransmission();
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val) {
// Convert binary coded decimal to normal decimal numbers
return ( (val/16*10) + (val%16) );
void printDate(){
// Reset the register pointer
Wire.write(zero);
Wire.requestFrom(DS1307_ADDRESS, 7);
int second = bcdToDec(Wire.read());
int minute = bcdToDec(Wire.read());
int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
int monthDay = bcdToDec(Wire.read());
int month = bcdToDec(Wire.read());
int year = bcdToDec(Wire.read());
/* int second = 11;
int minute =18;
int hour = 18;
int weekDay = 1;
int monthDay = 2;
int month = 11;
int year = 12;
//print the date EG 3/1/11 23:59:59
Serial.print(monthDay);
Serial.print("/");
Serial.print("/");
Serial.print(year);
Serial.print(" ");
Serial.print(hour);
Serial.print(":");
Serial.print(":");
// Serial.print("Week Day Of week");
// Serial.println(weekDay);
Arduino Playground - ModbusMaster Library - result of a 15 second effort with google ...
And the hard work if this library doesnt do what you need to : http://www.modbus.org/docs/Modbus_Application_Protocol_V1_1b.pdf (another 15 seconds with Google)
Good luck.
system
March 19, 2014, 11:56am
4
I could not able to download Modbus library . Site under construction
system
March 19, 2014, 12:05pm
6
Thanks . Since i am new to Learing modbus protocol. Let me know basic wiring diagram with arduino and Basic test program i can run over arduino with setup
system
7
system
March 19, 2014, 12:56pm
8
Do not keep cross-posting the same question and references to the same question.
system
March 19, 2014, 12:59pm
9
AWOL:
SOrry for that. I didn't find protocol column initially . SO i pasted i many
system
March 19, 2014, 1:13pm
10
That's the third account registered from the same IP address with very similar names.
Any comments?
system
January 10, 2015, 11:34am
11
We've completed the translation of our open source SCADA into English recently. It would be nice if Arduino developers use our SCADA, the source is here: GitHub - RapidScada/scada: Contains Rapid SCADA sources
Link for binaries: Rapid SCADA | Free, Open Source, Full Featured SCADA Software » Download
