modbus RTU esp32ModbusRTU
Trying the esp32ModbusRTU.h library from Bert Melis. Reading the Holding and Input registers works, but if I want to write to MultiHoldingRegister it reports an error:
invalid conversion from 'uint8_t {aka unsigned char}' to 'uint8_t * {aka unsigned char *}' [-fpermissive]
example here:
Copyright 2017 Bert Melis
This example reads 2 words (4 bytes) from the address 52 of the server with id 1.
address 52 = register 30053 (Eastron SDM630 Total System Power)
The ESP is connected to a max3485 with pins 17 (RX), 4 (TX) and 16 as RTS.
#include <Arduino.h>
#include <esp32ModbusRTU.h>
#include // for std: reverse
esp32ModbusRTU modbus (& Serial1, 16); // use Serial1 and pin 16 as RTS
uint8_t test;
void setup {
Serial.begin (115200); // Serial output
Serial1.begin (9600, SERIAL_8N1,17,4, true); // Modbus connection
modbus.onData ([] (uint6_t serverAddress, esp32Modbus :: FunctionCode fc, uint6_t * data, size_t length) {
Serial.printf ("id 0x% 02x fc 0x% 02x only% u: 0x", serverAddress, fc, length);
for (size_t i = 0; i <length; ++ i) {
Serial.printf ("% 02x", data );
  • std :: reverse (data, data + 4); // fix endianness*
    Serial.printf ("\ nval:% .2f", * reinterpret_cast <float *> (data));
  • Serial.print ("\ n \ n");*
  • modbus.onError ([] (esp32Modbus :: Error Error) {*
  • Serial.printf ("error: 0x% 02x \ n \ n", static_cast <uint8_t> (error));*
  • modbus.begin ();*
    void loop {
  • static uint32_t lastMillis = 0;*
  • if (millis () - lastMillis> 30000) {*
  • lastMillis = millis ();*
  • Serial.print ("sending Modbus request ... \ n");*
  • modbus.writeMultHoldingRegisters (0x01,52,2 test);*
The prototype for writeMultHoldingRegisters, extracted from the file that you included (esp32ModbusRTU.h):
bool writeMultHoldingRegisters(uint8_t slaveAddress, uint16_t address, uint16_t numberRegisters, uint8_t* data);
The last paramter must be a pointer to / address of a variable, in your case test.
So the first try would be to use
modbus.writeMultHoldingRegisters (0x01,52,2 &test);
Also note that the 3rd parameter should indicate the number of bytes following; you're telling it to expect two bytes so the connected device will probably get one byte of rubbish.
Please read How to use this forum - please read. - Installation & Troubleshooting - Arduino Forum, specifically point #7 about posting code.
Not sure how you think that this relates to "Interfacing w/ Software on the Computer"; this fits better in "Programming Questions" as you have a programming problem.
