Hi
I need to implement ModbusRTU on RS485. I'm using this module and it's connected to Serial3 pins on the Mega2560 board which are 14 and 15. Also, the DE and RE pins from the module are connected to pin 46 on the board. I wanted to use this library because it lets me choose the pins I'm using but I don't really understand how to use the _D variable (e.g. to turn on the built in LED). I thought maybe I could edit the source code on the ArduinoModbus and ArduinoRS485 libraries to set it up to use serial3 but I think I broke my library now LOL. If anyone could give me a hand on how to use that _D or how to edit the Arduino library I would be really grateful.
The code below is the example in the library I wanted to use first. I will also attach the .zip file of this library and the original arduinoRS485 and arduinoModbus libraries.
ModbusRTU_Slave_RS485.zip (22.0 KB)
ArduinoRS485 and ArduinoModbus.zip (101.7 KB)
#include <ModbusRTUSlave.h>
// size of data which will be read and written
#define DATA_SIZE 100
// data array which will be read and written
u16 _D[DATA_SIZE];
// address (kind of name) of above data, maybe anything
#define VIRTUAL_ADDRESS 0x7000
#define OUR_ID_AS_A_SLAVE 1
#define PIN_CONNECTED_TO_BOTH_DE_AND_RE 46
ModbusRTUSlave rtu(OUR_ID_AS_A_SLAVE, &Serial3, PIN_CONNECTED_TO_BOTH_DE_AND_RE);
rtu.addWordArea(VIRTUAL_ADDRESS, _D, DATA_SIZE);
rtu.begin(9600);
//Serial.begin(9600); // not needed, for logging purpose only
// set some value in data array to test if master can read and modify it
_D[0] = 160;
// waiting for requests from master
// reading and writing _D according to requests from master happens here
rtu.process();
The following is my attempt to set up the ArduinoRS485 library
#ifndef _RS485_H_INCLUDED
#define _RS485_H_INCLUDED
#include <Arduino.h>
#ifdef PIN_SERIAL3_TX
#define RS485_DEFAULT_TX_PIN PIN_SERIAL3_TX
#else
#define RS485_DEFAULT_TX_PIN 14
#endif
#ifdef __AVR__
#define RS845_DEFAULT_DE_PIN 46
#define RS845_DEFAULT_RE_PIN 46
#else
#endif
class RS485Class : public Stream {
public:
RS485Class(HardwareSerial& hwSerial, int txPin, int dePin, int rePin);
virtual void begin(unsigned long baudrate);
virtual void begin(unsigned long baudrate, uint16_t config);
virtual void end();
virtual int available();
virtual int peek();
virtual int read(void);
virtual void flush();
virtual size_t write(uint8_t b);
using Print::write; // pull in write(str) and write(buf, size) from Print
virtual operator bool();
void beginTransmission();
void endTransmission();
void receive();
void noReceive();
void sendBreak(unsigned int duration);
void sendBreakMicroseconds(unsigned int duration);
void setPins(int txPin, int dePin, int rePin);
private:
HardwareSerial* _serial;
int _txPin;
int _dePin;
int _rePin;
bool _transmisionBegun;
unsigned long _baudrate;
uint16_t _config;
extern RS485Class RS485;
#endif
This is the original arduino rs485.h looked like
#ifdef PIN_SERIAL1_TX
#define RS485_DEFAULT_TX_PIN PIN_SERIAL1_TX
#else
#endif
#ifdef __AVR__
#define RS845_DEFAULT_DE_PIN 2
#define RS845_DEFAULT_RE_PIN -1
#else
#define RS845_DEFAULT_DE_PIN A6
#define RS845_DEFAULT_RE_PIN A5
#endif
public:
virtual void end();
virtual int peek();
void receive();
void noReceive();
private:
int _txPin;
int _dePin;
int _rePin;
uint16_t _config;
#endif
