Hi there ! I’m sorry, I’ve no idea if I post this topic in the right section. I’m sure an admin will figure it out…
Anyway, I’ve troubles using a Modbus RTU device with my Arduino Nano.
Here is my code : (by the way, I’m kind of a new with Modbus and I’m still trying to figure it out so please be indulgent with my terrible coding ^^)
#include <ModbusMaster.h>
#define Max485_DE 2
#define Max485_RE_NEG 3
ModbusMaster node;
void preTransmission()
digitalWrite(Max485_RE_NEG, 1);
digitalWrite(Max485_DE, 1);
void postTransmission()
digitalWrite(Max485_RE_NEG, 0);
digitalWrite(Max485_DE, 0);
pinMode(Max485_RE_NEG, OUTPUT);
pinMode(Max485_DE, OUTPUT);
node.begin(10, Serial);
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
uint8_t resultMain;
resultMain = node.readInputRegisters(0x0053,1);
delay(580);
if (resultMain == node.ku8MBSuccess)
Serial.println(node.getResponseBuffer(0x53));
Before we go any further, yes my probe use a 9600 baud-rate, it’s ID is 10 and it needs a 580ms delay to send a response.
As you can see, I’m trying to get the data at the address 0x0053 and print it in my serial monitor. This data is a float. (don’t know if that can help)
Now, I found that code in a tutorial and it appeared to work just fine with his setup but for me, it only gets the letter “w”…
I just adapted the code to my needs.
Does someone have a solution ?
I have a LOT of infos about the probe and its precise Modbus RTU Protocole. So feel completely free to ask for any further information !
I thank you in advance for taking time to go through this for me. I appreciate that…
Nico
