Hello,
I am working on a project that interfaces a client PC with a environmental chamber over Modbus TCP. I am using KEPServerEX as the OPC server to communicate over TCP with the ardunio.
I am using 2 holding registers, one is being used to hold a setpoint value set by the PC and the other is holding the chamber temperature set by the chamber.
The problem I am getting is that the OPC server can’t seem to get the data from the arduino it says that the value is “Unknown” and the quality of the data is “Bad”. Also when I try and send it some data using the OPC Quick Client it says unable to write to address on device but when I look at the output the arduino gives me the value what was sent. So the write did work but the OPC server thinks it didn’t work.
I am not sure what the problem could be weather it might be something with the ArduinoModbus library or the OPC server or my code.
I am looking for any incite on how to make my project work.
For some other information the OPC Quick Client error when I try and write from it is "Failed on item ‘W.Mid_Chamber.TSW’ for asynchronous 2.0 write transaction 6C6D0CCF (HR=0x80004005) "
Here is my code:
#include <SPI.h>
#include <Ethernet.h>
#include <ArduinoModbus.h>
EthernetServer server(502);
ModbusTCPServer modbusTCPServer;
EthernetClient client;
float temp_send=25;
bool start = true;
float setpoint=0;
unsigned long previousMillis1 = 0;
unsigned long previousMillis2 = 0;
long interval1=500;
long interval2 =500;
uint16_t setpoint_modbus[2]={16840,0};
byte mac[] = { 0xA8, 0x61, 0x0A, 0xAE, 0x5C, 0x88 };
IPAddress ip (192,168,0,223);
IPAddress myDns(192, 168, 1, 1);
IPAddress gateway(192, 168, 0, 1);
byte subnet(255, 255, 255, 0);
Ethernet.init(10);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Ethernet.begin(mac, ip, myDns, gateway, subnet);
server.begin();
modbusTCPServer.begin();
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
//Serial.println(F("Ethernet shield was not found. Sorry, can't run without hardware."));
while (true) {
; // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
//Serial.println(F("Ethernet cable is not connected."));
modbusTCPServer.configureHoldingRegisters(0, 4);
Serial.println("step up done");
float readascii(){//read serial data can covert to float
String value;
bool isneg=false;
char input;
uint8_t len = 0;
float ans = 200;
while(Serial.available()){
input = Serial.read();
if(((input-'0')>=0 &&(input-'0')<=9)||(input=='.')&&(len<8)||(input == '-')){
value += (char)input;
len++;
if(len==0){
//Serial.println(F("made it here"));
return ans;
char valuechararray[len];
//value.toCharArray(valuechararray,len);
ans = value.toFloat();
return ans;
unsigned int f_2uint_int1(float float_number) { // split the float and return first unsigned integer
union f_2uint {
float f;
uint16_t i[2];
union f_2uint f_number;
f_number.f = float_number;
return f_number.i[0];
unsigned int f_2uint_int2(float float_number) { // split the float and return first unsigned integer
union f_2uint {
float f;
uint16_t i[2];
return f_number.i[1];
// waits for client to be available
if(client.connected()){
modbusTCPServer.accept(client);
// poll for Modbus TCP requests, while client connected
modbusTCPServer.poll();
if(start){ //init of chamber
Serial.println("start system");
delay(100);
Serial.println("set circulators = on");
delay(100);
start = false;
if(currentMillis - previousMillis1 >= interval1){
Serial.print("set setpoint 1 = ");
setpoint_modbus[0]=modbusTCPServer.holdingRegisterRead(0x00);
setpoint_modbus[1]=modbusTCPServer.holdingRegisterRead(0x01);
memcpy(&setpoint,setpoint_modbus,4);
Serial.println(setpoint); //set setpoint for chamber
previousMillis1 = currentMillis;
if(currentMillis - previousMillis1 >= interval2){
Serial.println("read pv 1");//ask chamber for temp
delay(10);
temp_send=readascii(); //read chamber temp
if(temp_send!=200){//if different send to client
uint16_t low_order =f_2uint_int1(temp_send);
uint16_t big_order =f_2uint_int2(temp_send);
modbusTCPServer.holdingRegisterWrite(0x02,low_order);//send bits 0-15
modbusTCPServer.holdingRegisterWrite(0x03,big_order);//send bits 16-31
