Hello, I’m a newbie to Arduino. I have been working on a DC voltmeter. I’m using examples found online. I have it working great and displaying the voltage on an LCD display. Really cool. Now, I’m wanting to add Modbus Protocol to display the voltage on a SCADA / HMI application. I do have it working, but I can’t seem to figure out this last thing.
Measuring a 12v battery, the LCD display shows 12.57v. The same as my meter. Success. I’m using Indusoft Web Studio 7.1 as my HMI software, and I do have it reading the arduino using modbus, but it will only display 12v. Nothing on the other side of the decimal. Only whole numbers. I have tried everything I can think of, and different HMI applications all with the same results.
Could someone please look over the sketch and see what I might be doing wrong?
Thank you so much for any help.
// include the library code:
#include <LiquidCrystal.h>
#include <SPI.h>
#include <Ethernet.h>
#include <Mudbus.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 5, 9, 1, 0);
int backLight = 6; // pin 6 will control the backlight
int analogInput = 0;
float vout = 0.0;
float vin = 0.0;
float R1 = 100000.0; // resistance of R1 (100K)
float R2 = 9900.0; // resistance of R2 (10K)
int value = 0;
Mudbus Mb;
uint8_t mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x51, 0x06 };
uint8_t ip[] = { 192, 168, 1, 141 };
uint8_t gateway[] = { 192, 168, 1, 1 };
uint8_t subnet[] = { 255, 255, 255, 0 };
Ethernet.begin(mac, ip, gateway, subnet);
//Avoid pins 4,10,11,12,13 when using ethernet shield
delay(5000); //Time to open the terminal
pinMode(backLight, OUTPUT);
pinMode(analogInput, INPUT);
digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
lcd.begin(16, 2);
lcd.print(" ModBus ");
lcd.setCursor(0, 1);
lcd.print(" DC Voltmeter ");
delay(2000);
lcd.clear();
lcd.print(" Version: 2.0 ");
delay(1500);
lcd.clear();
lcd.print("Modbus Voltmeter");
Mb.R[0] = 0.00;
//modbus TCP update
Mb.Run();
// read the value at analog input
value = analogRead(analogInput);
vout = (value * 4.81) / 1024.0;
vin = vout / (R2/(R1+R2));
if (vin<0.09) {
vin=0.0; //statement to quash undesired reading !
Mb.R[0] = (vin);
lcd.print("INPUT V = ");
lcd.print(vin);
delay(400);
