I have this project where I need a modbus tcp server that will host a series of sensor data for other modbus client devices to read. I use this Library by Andresoarmento
This is the code i am using from the library example:
#include <EtherCard.h>
#include <Modbus.h>
#include <ModbusIP_ENC28J60.h>
//Modbus Registers Offsets (0-9999)
const int SENSOR_IREG = 100;
//Used Pins
//const int sensorPin = A0;
//ModbusIP object
ModbusIP mb;
long ts;
// The media access control (ethernet hardware) address for the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// The IP address for the shield
byte ip[] = { 192, 168, 1, 120 };
//Config Modbus IP
mb.config(mac, ip);
// Add SENSOR_IREG register - Use addIreg() for analog Inputs
int i = 2200;
mb.addIreg(SENSOR_IREG,i);
ts = millis();
//Call once inside loop() - all magic here
mb.task();
//Read each two seconds
if (millis() > ts + 2000) {
ts = millis();
//Setting raw value (0-1024)
int i = 0;
i++;
mb.Ireg(SENSOR_IREG, i);
The enj28j60 module is working as i tested it. So, I used a modbus scanner(CAS SCANNER) which was unable to detect it. Can anyone tell me how to get this all working and test it?
Oh yes, I Connected it to a router and scanned using the CAS scanner. The CAS scanner polled a input register read command and i got a 0x02 error. as a response from the device.
deapool:
So the Modbus server works as expected. Error 2 means that the register with the given address does not exist.
I thought the same. But, I still can't figure out if the error is because of the CAS scanner or my code. I have attached the CAS error log with this post.
This time i tried with a holding register.
And below is the code I use to store data into the holding register.
#include <Modbus.h>
//Used Pins
//ModbusIP object
ModbusIP mb;
long ts;
void setup() {Serial.begin(9600);
//Config Modbus IP
mb.config(mac, ip);
//mb.addIreg(SENSOR_IREG);
mb.addHreg(SENSOR_IREG);
ts = millis();
mb.task();
ts = millis();
//mb.Ireg(SENSOR_IREG, analogRead(sensorPin));
mb.Hreg(SENSOR_IREG, 255); //Store value in holding register
I am unable figure out what the problem is. I checked the library files, it is able to receive the data and parse it. Just not able to send the data I want. Being very new to this protocol of communication, Any help is appreciated.
According to the screenshot it's that scanner. Requesting 100 registers starting at address 0 is quite rather stupid for a device that has only one register at address 100. So as I wrote, the Arduino is acting correctly as it doesn't have any register at the addresses 0-99.
The explanation your scanner software offers is correct but it seems you haven't read it. The only drawback of that explanation is that it assumes that every device starts at address 0 with the registers.
This makes sense, I couldn't quite understand the CAS scanner and didn't know it has been requesting data from a address that is not there in the first place. This also explains the error code. I will try to add hundred registers in the device or try to use a different scanner that can read a specified address! Thanks for the help, Pylon. I will try it and let you know!!
Hi All,
I'm using the Andre Sarmento as the original poster and I'm having a couple of issues. I'm using an Uno and a ethernet shield.
this is my code:
Modbus-Arduino Example - Servo (Modbus IP ENC28J60)
Copyright by André Sarmento Barbosa
http://github.com/andresarmento/modbus-arduino
#include "Modbus.h"
#include "ModbusIP_ENC28J60.h"
// Modbus Registers Offsets (0-9999)
const int temp_HREG = 0;
int numberOfSensors = 40;
long ts;
// ModbusIP object
ModbusIP mb;
Serial.println("ready");
byte mac[] = { 0xA8, 0x61, 0x0A, 0xAE, 0x85, 0x80 }; // Define MAc address
byte ip[] = { 10, 0, 41, 91 }; // Define IP address
byte subnet[] = { 255, 255, 254, 0 };
//Config Modbus IP
mb.config(mac, ip);
Serial.println("mb config");
// Filling holding registers
for(uint16_t i = temp_HREG; i < numberOfSensors; i++)
mb.addHreg(i, i);
//Serial.println(res, DEC);
ts = millis();
mb.task();
ts = millis();
for(uint16_t i = 0; i < numberOfSensors; i++)
Serial.println(mb.Hreg(i), DEC);
I'm using Serial outputs to debug the program and it seems I get into mb.config(mac, ip) and I'm not coming out of that as my following serial print is not actiuvated.
I also get these warnings on compile:
In function 'send_dhcp_message':
warning: 'memset' writing 278 bytes into a region of size 200 overflows the destination [-Wstringop-overflow=]
memset(gPB, 0, UDP_DATA_P + sizeof( DHCPdata ));
