Hello,
I am trying to connect an arduino uno to Kepware (soft OPC) which allows me to read with Kepware some arduino tags.
At this moment I'm starting this project, and that's the reason I'm here, to see if anyone has already done or have seen something similar that can indicate me something.
The idea is to use one connection Modbus TCP with one shield ethernet on the arduino uno for exemple.
Everything is welcome.
Thanks.
Welcome to the forum.
But you need to explain your requirement in more detail and clearer. For example, are you setting up the Arduino as Modbus TCP slave or master?
What have you already tried ?
What Modbus TCP library have you looked at using so far ?
When detailing other hardware or software, please provide links so it is easier for us.
For example, don't assume we know which Ethernet shield you are using.
Paul - VK7KPA
