Modbus TCP read input registers moxa E1200 devices
Hello to all,
this is my first message.
I have a problem with modbus TCP.
I have 2 moxa modules Moxa E1210 with 16 inputs and 1 Moxa E1212 with 8in and 8out.
I want to read the state of digital inputs using modbus tcp.
In the moxa manuals i've to read DI-all_statusFromDI-00,
Start Address (decimal): 0048 witch FC code 04:INPUT REGISTER and the moxa adapter replies me with 1 word data.
I tried to read al teast 1 module, but when i execute the sketch the call of requestFrom gives me the reply: invalid argument.
I've written this code:
arduino-modbus-tcp-forum.ino (2.5 KB)
Pleas help me!
Thank a lot.
if (!slave.connected()) {
    slave.stop();
    slave.connect(slaveIp, slavePort);
You shouldn't handle the TCP connection yourself, the Modbus library should do that. Take a look at the corresponding examples!
Thanks for your reply!
I've always the same problem: invalid argument on the modbus request
I know, my last response tells you why you have these errors.
I've already removed the code
if (!slave.connected()) { slave.stop(); slave.connect(slaveIp, slavePort); }
But It doesn't work fine :frowning:
Removing the code isn't all you have to do. You must call the corresponding code in the Modbus library.
Did you have a look at the examples of your library?
Hi pylon,
i've seen the example better as you tell and i resolved the problem.
What changes now if i want to add the other servers?
Can i poll in the same sketch to modbus rtu devices (having the Arduino interface)?
Thanks a lot.
Create one modbus client object per server.
Theoretically, yes. What Arduino board are you using? What RS485 hardware do you intend to use?
