Modbus TCP Server - Arduino Uno with ethernet shield
Hello!
I am using an Arduino Uno with an ethernet shield on top as my server, and I want to send and recieve data using Modbus TCP. I am using arduinos ArduinoModbus library.
Right now I am only trying to read a coil on the server from my client (raspberry pi 3). The modbus message is received on the server, but it's not sending back a modbus message with the data on the coil. The client then get a timeout error after a few seconds.
Any ideas?
#include <SPI.h>
#include <Ethernet.h>
#include <ArduinoRS485.h> // ArduinoModbus depends on the ArduinoRS485 library
#include <ArduinoModbus.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 177);
IPAddress myDns(192, 168, 1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 0, 0);
// TCP defaults to port 502
EthernetServer server(502);
ModbusTCPServer modbusTCPServer;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Modbus TCP Server Setup");
  // configure the LED
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
    ------- Ethernet Init -------
  // Initialize the ethernet device
  Ethernet.begin(mac, ip, myDns, gateway, subnet);
  if (Ethernet.begin(mac) == 0)
		Serial.println("Failed to configure Ethernet using DHCP");
		// No point in carrying on, stop here forever.
		while(true) ;
  // Check for Ethernet hardware present
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    while (true) {
      delay(1); // do nothing, no point running without Ethernet hardware
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
  // start listening for clients
  server.begin();
  Serial.print("Server address: ");
  Serial.println(Ethernet.localIP());
    ------- Modbus Init -------
  // start the Modbus TCP server with slaveID 1
  if (!modbusTCPServer.begin(1)) {
    Serial.println("Failed to start Modbus TCP Server!");
    while (1);
  // configure a single coil at address 0x3E
  if (!(modbusTCPServer.configureCoils(0x3E, 1)==1)){
    Serial.println("Failed to configure coils");
    while (1);
  Serial.println("Successfully started Modbus TCP Server!");
  // listen for incoming clients
  if (client) {
    // a new client connected
    Serial.println("new client");
    // let the Modbus TCP accept the connection
    modbusTCPServer.accept(client);
    Serial.println("accepted client");
    while (client.connected()) {
      // poll for Modbus TCP requests, while client connected
      modbusTCPServer.poll();
      // update the LED
      updateLED();
    Serial.println("client disconnected");
void updateLED() {
  // read the current value of the coil
  int coilValue = modbusTCPServer.coilRead(0x3E);
  Serial.println(coilValue);
  if (coilValue) {
    // coil value set, turn LED on
    digitalWrite(LED_BUILTIN, HIGH);
    // coil value clear, turn LED off
Please post the Arduino serial output you got!
Did you sniff the network segment to log the network traffic between the two nodes? If yes, please post the dumped data.
