Modbus testing basic
Dear all,
I need help in debugging the simple modbus example code.I have attached all relevant information here.The code upload successfully without any error. i am using aRDUINO 1.0.6 VERSION.on windows xp platform.When i send request serially i am not getting any response from slave.
Test setup 1: without max 485 IC. I am trying to send request same as in diagram with RS23S communication
USB to TTL out put
TX OF ttl out goes to pin 3 atmegaIC
RX of TTL goes to pin 2 atmega IC
GND are common
TEST SETUP 2: with RS485 shield
PIN2 ATMEGA328-> RS 485 sheild pin 0
PIN3 ATMEGA328-> RS 485 sheild pin 1
5v & GND are given from controller board.
library1:ModbusRTU
library 2:simple modbus
https://drive.google.com/folderview?id=0B0B286tJkafVYnBhNGo4N3poQ2c&usp=drive_web&tid=0B0B286tJkafVSENVcU1RQVBfSzg
I am using atmega328 on customized board. I already tested all functionality so it working fine up to serial communication.my next step to implement mod bus protocol. I would like to test below example code.
code 1:
#include <SimpleModbusSlave.h>
#define  LED 9
enum
  // just add or remove registers and your good to go...
  // The first register starts at address 0
  ADC_VAL,
  PWM_VAL,
  HOLDING_REGS_SIZE // leave this one
  // total number of registers for function 3 and 16 share the same register array
  // i.e. the same address space
unsigned int holdingRegs[HOLDING_REGS_SIZE]; // function 3 and 16 register array
  modbus_configure(&Serial, 9600, SERIAL_8N2, 1, 2, HOLDING_REGS_SIZE, holdingRegs);
  // modbus_update_comms(baud, byteFormat, id) is not needed but allows for easy update of the
  // port variables and slave id dynamically in any function.
  modbus_update_comms(9600, SERIAL_8N2, 1);
  pinMode(LED, OUTPUT);
  modbus_update();
  holdingRegs[ADC_VAL] = analogRead(A0); // update data to be read by the master to adjust the PWM
  analogWrite(LED, holdingRegs[PWM_VAL] >> 2); // constrain adc value from the arduino master to 255
code 2
 *  Modbus slave example 2:
 *  The purpose of this example is to link the Arduino digital and analog
 *	pins to an external device.
 *  Recommended Modbus Master: QModbus
 *  http://qmodbus.sourceforge.net/
#include <ModbusRtu.h>
#define ID   1
Modbus slave(ID, 0, 0); // this is slave ID and RS-232 or USB-FTDI
boolean led;
int8_t state = 0;
unsigned long tempus;
// data array for modbus network sharing
uint16_t au16data[9];
 *  Setup procedure
  io_setup(); // I/O settings
  // start communication
  slave.begin( 19200 );
  tempus = millis() + 100;
  digitalWrite(13, HIGH );
 *  Loop procedure
  // poll messages
  // blink led pin on each valid message
  state = slave.poll( au16data, 9 );
  if (state > 4) {
    tempus = millis() + 50;
    digitalWrite(13, HIGH);
  if (millis() > tempus) digitalWrite(13, LOW );
  // link the Arduino pins to the Modbus array
  io_poll();
void io_setup() {
  // define i/o
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(13, OUTPUT);
  digitalWrite(6, LOW );
  digitalWrite(7, LOW );
  digitalWrite(8, LOW );
  digitalWrite(9, LOW );
  digitalWrite(13, HIGH ); // this is for the UNO led pin
  analogWrite(10, 0 );
  analogWrite(11, 0 );
 *  Link between the Arduino pins and the Modbus array
void io_poll() {
  // get digital inputs -> au16data[0]
  bitWrite( au16data[0], 0, digitalRead( 2 ));
  bitWrite( au16data[0], 1, digitalRead( 3 ));
  bitWrite( au16data[0], 2, digitalRead( 4 ));
  bitWrite( au16data[0], 3, digitalRead( 5 ));
  // set digital outputs -> au16data[1]
  digitalWrite( 6, bitRead( au16data[1], 0 ));
  digitalWrite( 7, bitRead( au16data[1], 1 ));
  digitalWrite( 8, bitRead( au16data[1], 2 ));
  digitalWrite( 9, bitRead( au16data[1], 3 ));
  // set analog outputs
  analogWrite( 10, au16data[2] );
  analogWrite( 11, au16data[3] );
  // read analog inputs
  au16data[4] = analogRead( 0 );
  au16data[5] = analogRead( 1 );
  // diagnose communication
  au16data[6] = slave.getInCnt();
  au16data[7] = slave.getOutCnt();
  au16data[8] = slave.getErrCnt();
libraries.zip (233 KB)
