Modbus timeout error rate is 30 ~ 40%.
I am using the modbus tool from https://www.modbustools.com/.
And arduino due is using the following code: Arduino/SimpleModbusSlaveArduino.ino at master · pepsilla/Arduino · GitHub
The code above works 100% without error.
However, integrating Modbus code from previously created code will result in timeout errors.
For example, if I send 8,000 times TX signals, I receive RX signals about 2000 times.
Response Timeout, Delay Between Polls, Connect Time, and Scan Rate were all set to 1000ms.
my loop() code is as follow :
loop(){
    if (Flag03){
      INTERNAL_SENSOR();
    else if (Flag04){
      SAVE_INFO();
    else if(Flag05){
      CHECK_SDCARD();
    else{
      recvWithEndMarker();
      showNewData();
      modbus_update();
      holdingRegs[0] = 1234; // update data to be read
This entire loop runs in less than a second.
But, this code makes a lot of timeout error.
Always post complete code!
You must call modbus_update() in every run through loop(), at least several times a second. Most probably this is the reason for your timeouts. If your loop() needs almost a second to run and you even don't call modbus_update() in every run, it's not surprising that it doesn't work.
