I made some projects in tha past, but I am very inexperienced in protocoll work except Serial.Print command feeding back data via USB.
Here is my question. I'd like to connect a sensor (and the interface to the sensor is not problem) to feed into a engine control unit. The engine control unit has the following data shown on their webpage:
Modbus 57600 baud
8N1 format
no hardware handshaking
Total 47 Bytes per packet
- Byte 0 = slave address = 0x01
- Byte 1 = command = 0x03 (read holding registers)
- Byte 2 = word count = 21 (there are 21 word values for the gauges to log)
- Bytes 3 to 44 = actual data
- Bytes 45 and 46 = CRC (can be used for data integrity, or can be ignored).
Can someone give me a hint how to implement this into Arduino? :~
