ModbusMaster library for Arduino
This project implements a Modbus RTU Master for the Arduino microcontroller. The code is packaged as an Arduino library, complete with example sketches.
Project: http://code.google.com/p/modbusmaster/
The Playground wiki has been updated to include the above link. Code has been tested on a Phoenix Contact nanoLC controller.
The following Modbus functions have been implemented:
  • 0x01 - Read Coils
  • 0x02 - Read Discrete Inputs
  • 0x05 - Write Single Coil
  • 0x0F - Write Multiple Coils
  • 0x03 - Read Holding Registers
  • 0x04 - Read Input Registers
  • 0x06 - Write Single Register
  • 0x10 - Write Multiple Registers
  • 0x16 - Mask Write Register
  • 0x17 - Read Write Multiple Registers
Feedback is welcome.
Rx
Project inspired by Arduino Modbus Master http://sites.google.com/site/jpmzometa/arduino-mbrt/arduino-modbus-master.
Nice! Might going to use this with a operator screen I have which has modbus as one of it's protocols.
The class has been revised so each object instantiation is tied to a particular Modbus slave. Functions have been added to get/set private variables and Modbus functions have been updated to simplify end user coding. See project Source tab for details on specific changes.
To do: - implement ability to select UART during object instantiation (on Arduinos with >1 UART)- add function to retrieve register data as 32-bit long words- add range checking on get/set functions Rx
You can now select serial ports 0..3. Range checking is implemented on get/set methods RX/TX. See project Source tab for details on specific changes.
Rx
