ModBusRTU compile error
Hello
I found error after verify the code per below. Pls help on what possible cause this error?
I try to read data from the device (RS485 interface) with Mega.
Slave address: 254
Register: 113
the error is “READ_INPUT_REGISTERS” was not declared in this scope"
//master mega
#include <SimpleModbusMaster.h>
//////////////////// Port information ///////////////////
#define baud 9600
#define timeout 1000
#define polling 200 // the scan rate
#define retry_count 10
// used to toggle the receive/transmit pin on the driver
#define TxEnablePin 2
// The total amount of available memory on the master to store data
#define TOTAL_NO_OF_REGISTERS 13
// This is the easiest way to create new packets
// Add as many as you want. TOTAL_NO_OF_PACKETS
// is automatically updated.
enum
  PACKET1,
  PACKET2,
  PACKET3,
  PACKET4,
  TOTAL_NO_OF_PACKETS // leave this last entry
// Create an array of Packets to be configured
Packet packets[TOTAL_NO_OF_PACKETS];
// Masters register array
unsigned int regs[TOTAL_NO_OF_REGISTERS];
  //read data from slave 1 in reg slot 2 and store in regs[0]
 modbus_construct(&packets[PACKET1], 254, READ_INPUT_REGISTERS, 113, 1, 10); //test this line read input 1 to regs0 and 2 to regs1 slave 1 i.e read both reg on slave?
  modbus_configure(&Serial1, baud, SERIAL_8N1, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS, regs);
  modbus_update();
  float Pressure, Pressure1, Pressure2;
  Pressure = regs(10)
  Serial.println("CHECK        || OUTPUT");
  Serial.print(packets(PACKET1).requests);
  Serial.print("         || Pressure: ");
  Serial.print(Pressure);
  Serial.println("PSI");
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
C:\Users\VDO210919\Desktop\Adruino code\Mod_bus_code\Mod_bus_code.ino: In function 'void setup()':
Mod_bus_code:41:43: error: 'READ_INPUT_REGISTERS' was not declared in this scope
C:\Users\VDO210919\Desktop\Adruino code\Mod_bus_code\Mod_bus_code.ino:41:43: note: suggested alternative: 'READ_HOLDING_REGISTERS'
Mod_bus_code:41:2: error: 'modbus_construct' was not declared in this scope
C:\Users\VDO210919\Desktop\Adruino code\Mod_bus_code\Mod_bus_code.ino:41:2: note: suggested alternative: 'modbus_configure'
  modbus_configure
Mod_bus_code:43:21: error: 'Serial1' was not declared in this scope
C:\Users\VDO210919\Desktop\Adruino code\Mod_bus_code\Mod_bus_code.ino:43:21: note: suggested alternative: 'Serial'
                     Serial
C:\Users\VDO210919\Desktop\Adruino code\Mod_bus_code\Mod_bus_code.ino: In function 'void loop()':
Mod_bus_code:49:17: error: too few arguments to function 'unsigned int modbus_update(Packet*)'
   modbus_update();
In file included from C:\Users\VDO210919\Desktop\Adruino code\Mod_bus_code\Mod_bus_code.ino:2:0:
C:\Program Files (x86)\Arduino\libraries\SimpleModbusMaster/SimpleModbusMaster.h:142:14: note: declared here
 unsigned int modbus_update(Packet* packets);
Mod_bus_code:51:21: error: 'regs' cannot be used as a function
   Pressure = regs(10)
Mod_bus_code:55:31: error: 'packets' cannot be used as a function
exit status 1
option enabled in File -> Preferences.
Thanks
Mike
Did you install the library?
