Code Assitant needed or please anyone suggest a library that support physical or software slave ID change For MODBUS .
Anyone who already built is appreciated.
Thank you
There is a setID() method for exactly that purpose.
How to use that Function i dont understand tried all things but no result.
Can you provide me any example?
You provide the new address as a parameter to the method.
uint8_t new_id = 8;
slave.setID(new_id);
where slave is the initialized ModbusRTU object.
I don't understand where you see a problem. Maybe you should explain what you don't understand.
Hey Pylon
I am very new to Arduino Programming i do understand whole modbus but i don't understand the mux DIP switch to change slave ID if you provide any snippet how it should be declared .
Only Changing the slave ID part i don't understand with MUX.
No clue what you're writing about. What MUX? As it seems to have DIP switches it must be some kind of hardware. As you failed to provide a link to that hardware we cannot help.
Hey Pylon,
Can you share me the code which has DIP switch slave configurable settings , and mux hardware connections?
Your help will be blessing gift to me.
No, you still failed to provide necessary information about the hardware you're using.
I already posted for the ModbusRTU.h library to change the slave ID. Maybe that works for, otherwise provide the information we asked for!
