Mode changeing with button
In line 59 and 70, When I press the buttons the serial doesnt always write
sometiemes it does sometimes it is random. Although When i remove mode--; and mode++; it seams to work fine... Please help!
#include <Arduino.h>
#include <LiquidCrystal.h>
#include <Wire.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//Pinouts
int l298n_enable = 6;
int l298n_in1 = 7;
int ledr;
int ledg;
int pot = A0;
int mode_up_pin = 9;
int mode_down_pin = 13;
//Variables
int l298n_pwm = 0;
int mode = 0;
bool l298n_active = true;
int mode_up_state = 0;
int mode_down_state = 0;
int last_up_state = 0;
int last_down_state = 0;
   //Pinmodes
    pinMode(l298n_enable, OUTPUT);
    pinMode(l298n_in1, OUTPUT);
    // pinMode(ledr, OUTPUT);
    // pinMode(ledg, OUTPUT);
    pinMode(pot, INPUT);
    pinMode(mode_up_pin, INPUT);
    pinMode(mode_down_pin, INPUT);
    //set motor direction
    digitalWrite(l298n_in1, HIGH);
    lcd.begin(16, 2);
      lcd.print("hello, world!");
    //Write Pot value to motor
    l298n_pwm = analogRead(pot);
    l298n_pwm = map(l298n_pwm, 0, 1023, 0, 255);
    if (l298n_active == true) { //Only write if it is ment to be active
        analogWrite(l298n_enable, l298n_pwm);
    //mode up logic
    mode_up_state = digitalRead(mode_up_pin);
    if (mode_up_state != last_up_state && mode_up_state == HIGH) {
            mode++;
            delay(50);
            Serial.write("up");
    last_up_state = mode_up_state;
    //mode doqn logic
    mode_down_state = digitalRead(mode_down_pin);
    if (mode_down_state != last_down_state && mode_down_state == HIGH) {
            mode--;
            delay(50);
            Serial.write("down");
    last_down_state = mode_down_state;
    //Stops mode from going below 0
    if (mode < 0) {
        mode = 0;
    //Stops mode from going above 1
    if (mode > 1) {
        mode = 1;
    if (mode == 0) {
    if (mode == 1) {
        delay(2000);
        l298n_active = false;
        delay(2000);
Hello my friend
It does not work because the code does not recognize" mode"
Did you mention it in the code that it means something?
Should be
    if (mode_up_state != last_up_state) {
      if ( mode_up_state == HIGH) {
            mode++;
            Serial.write("up");
        delay(50);
You are constantly assigning the present state to the last state. You are recording the last state change, therefore you should only do it when the state does change.
first, what is recognize mode and second what do you mean by means something
Just tried the new code and it is having the same issue...
It is just a hint. There is lots of other code to fix. I edited the post with an explanation of the mistake.
Don't just try it, try to understand it.
yeah I saw thanks but im still thrown for a loop about that other part...
What other part?
the why removing mode++ and mode-- fixes it
Well, does it matter? I doubt that removing it makes the program work, but if it does, accept it and move on...
Seems to me it would make the controls inactive...
the program is ment to serial write when i click the button but it doesnt always write, I need the mode++ and -- though
Im trying to figure out why that it is causing an issue and fix it
Then learn C++ programming. Can you explain in English words, what your program does? There is no documentation and only bare minimum comment lines...
To make it work, you have to know how it should work.
just figured out what you meant, I defined it earlier sa an int, was their more I needed to do?
working on a projct that has a jet of water and it kindof dances / goes up and down. The LCd shows the mode it is in and the modes are different settings for the bouncy water thing
When I press the mode up it should shift the mode up 1 to do a diffrent pattern with the water. down should do the same but shift the mode down 1
also dont ask about the project lol i dont have the braincells left in me to explain where the idea came from
What I want is a complete functional description like:
  1. When the up button is pressed, "up" is printed and the mode is incremented
... etc.
Good luck with it. Bye!
  2. When the down button is pressed, "down" is printed and the mode is incremented downwards
