Mode Switch Middle of if statement??
Hey all,
I have some code that runs a LED strip. My problem is one of the “effects” I have is that it turns on different LED’s (Making a rainbow)(red on, blue on, red off, green on, etc…). However, the thing I don’t like is that it is not being registered that a button is being pushed to switch modes until it reaches the end of the effect…
Is there a piece of code (or a command) that will read in a button push in the middle of an if statement? I know that it’s in the middle of an if while in a loop, so it may not be possible and mode switch may only be able to happen at the end of the command. I don’t know if there is an on button interrupt?
Mode 8 in the code is the one I’m looking at…mode 7 does the same as well.
Thanks in advance for help!
Not all code is mine!!
 Some code by Joshua David --- TechHelpBlog.com
 Some code by Arduino.CC
 Some code by Adafruit for SetColor;
 Some code found for public domain use (author not in comments)
 all compliled by Lance == cub526 and free to use!!
// this constant won't change:
const int buttonPin = 2;    // the pin that the pushbutton is attached to
const int ledPin = 13;       // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
//variables for our pins
int redPin = 9;
int greenPin = 10;
int bluePin = 11;
//Set Initial Values
int RedVal = 0;
int GreenVal = 0;
int BlueVal = 0;
int fade = 15;  // Delay Time
//two colors below are my school colors
//midnight blue
int RedVal1 = 25;
int GreenVal1 = 25;
int BlueVal1 = 112;
//gold
// Colour Value 2
int RedVal2 = 255;
int GreenVal2 = 215;
int BlueVal2 = 0;
int mode = 1; //used for mode slection in certain if's
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // initialize serial communication:
  // read the pushbutton input pin:
buttonModeChange();
  if (buttonPushCounter == 10) { //we've hit the end of the loop, go back to one!
    buttonPushCounter = 1;
    Serial.println("Change");
  if (buttonPushCounter == 1) {//red
    setColor(255, 0, 0);
    Serial.println("1");
  if (buttonPushCounter == 2) {
    setColor(0, 255, 0); // green
    Serial.println("2");
  if (buttonPushCounter == 3) {
    setColor(0, 0, 255); // blue
    Serial.println("3");
  if (buttonPushCounter == 4) {
    setColor(255, 255, 0); // YELLOW
    Serial.println("4");
  if (buttonPushCounter == 5) { //fade between two colors
    if(mode == 1){
      if(RedVal < RedVal1){              // If RedVal is less than desired RedVal1
        RedVal ++;                       // increment RedVal
      else if(RedVal > RedVal1){       // If RedVal is more than desired RedVal1
        RedVal --;                       // decrement RedVal
      else if(RedVal == RedVal1){      // If RedVal is equal to desired RedVal1
        //Do Nothing
      // Repeated as above for BlueVal
      if(BlueVal < BlueVal1){
        BlueVal ++;
      else if(BlueVal > BlueVal1){
        BlueVal --;
      else if(BlueVal == BlueVal1){
        //Do Nothing
      // Repeated as above for GreenVal
      if(GreenVal < GreenVal1){
        GreenVal ++;
      else if (GreenVal > GreenVal1){
        GreenVal --;
      else if (GreenVal == GreenVal1){
        // Do Nothing
      // Now we have a new set of values, we write them to the PWM Pins.
      analogWrite(redPin, RedVal);
      analogWrite(greenPin, GreenVal);
      analogWrite(bluePin, BlueVal);
      delay(fade);                       // Implement a bit of delay to slow the change of colour down a bit
      if(RedVal == RedVal1 && GreenVal == GreenVal1 && BlueVal == BlueVal1){ // If RedVal & GreenVal & BlueVal are all at the desired values
        delay(1500);                     // Delay to hold this colour for a little while
        mode = 2;                        // Change the mode to the next colour. Exiting this while loop and into the next one
    if (mode == 2){
      if(RedVal < RedVal2){              // If RedVal is less than desired RedVal1
      else if(RedVal > RedVal2){       // If RedVal is more than desired RedVal1
      else if(RedVal == RedVal2){      // If RedVal is equal to desired RedVal1
        //Do Nothing
      if(BlueVal < BlueVal2){
        BlueVal ++;
      else if(BlueVal > BlueVal2){
        BlueVal --;
      else if(BlueVal == BlueVal2){
        //Do Nothing
      if(GreenVal < GreenVal2){
        GreenVal ++;
      else if (GreenVal > GreenVal2){
        GreenVal --;
      else if (GreenVal == GreenVal2){
        // Do Nothing
      if(RedVal == RedVal2 && GreenVal == GreenVal2 && BlueVal == BlueVal2){ // If RedVal & GreenVal & BlueVal are all at the desired values
        mode = 1;                        // Change the mode to the next colour. Exiting this while loop and into the next one
  if (buttonPushCounter == 6){ // all white
    setColor(255,255,255);
    Serial.println("6");
    mode = 1; //for the previous effect, need to change this back to 1 for future use (we don't know what it was before)
  if (buttonPushCounter == 7) //fourth of july Effect
    if (mode == 1){
      setColor(255, 0, 0); // red
      delay(250);
      mode = 2;
    if (mode ==2)
      setColor(255, 255, 255); // white
      delay(250);
      mode = 3;
    if (mode ==3)
      delay(250);
      mode = 1;
  if (buttonPushCounter == 8)
    int r, g, b;
    // fade from blue to violet
    for (r = 0; r < 255; r++) {
      analogWrite(redPin, r);
      delay(fade);
    // fade from violet to red
    for (b = 255; b > 0; b--) {
      analogWrite(bluePin, b);
      delay(fade);
    // fade from red to yellow
    for (g = 0; g < 255; g++) {
      analogWrite(greenPin, g);
      delay(fade);
    // fade from yellow to green
    for (r = 255; r > 0; r--) {
      delay(fade);
    // fade from green to teal
    for (b = 0; b < 255; b++) {
      delay(fade);
    // fade from teal to blue
    for (g = 255; g > 0; g--) {
      delay(fade+3);
  if (buttonPushCounter == 9)
    setColor(0,0,0); //all off
    Serial.println("ALL OFF: 8");
    mode =1; //all done for loop, mode = 1 again just in case;
void setColor(int red, int green, int blue) {
  analogWrite(redPin, red);
  analogWrite(greenPin, green);
  analogWrite(bluePin, blue);
void buttonModeChange ()
   buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button
      // wend from off to on:
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes:  ");
      Serial.println(buttonPushCounter);
    else {
      // if the current state is LOW then the button
      // wend from on to off:
      Serial.println("off");
  lastButtonState = buttonState;
cub526: I don't know if there is an on button interrupt?
There are interrupts, but you're not looking for an interrupt. The kind of interrupts that are available are akin to the doorbell ringing while you are cooking dinner. The doorbell rings, you answer it, then go back to cooking dinner. The problem your code has is blocking statements like delay(). The delay() function tells the processor to sit around and twiddle its thumbs until the delay ends. What you'll need to do is read, understand and embrace the concepts demonstrated in the Blink Without Delay example.
you can put a read of a pin inside an if statement and combine it with other boolean expressions.
if ( (digitalRead(pin) == HIGH) .... rest of the test .... )
