Trying to figure out the programming for a model engine thrust dynamometer; build the hardware but now struggling with the programming as I have “0” experience with this kind of programming...found a script that does what I like the dynamometer to do but when I check the code there are error reports. I use an Arduino UNO, load cell, HX711 type board (with 80 measurements a second) and a keypad shield...I would like the dynamometer to be self-zeroing, start with a button push, have a 10 second delay before starting and than records for 10 seconds so I can convert the readout afterwards in Excell...
code that I found is as follows:
[color=#24292e][/color]
Model Rocket Engine Dynamometer - Nick Cinquino 9/1/15 - V.5 Original 10Kg loadcell
Modified from Nathan Seidle, SparkFun Electronics, November 19th, 2014
Output data in grams (g). There are 101.97 gram-force per Newton, for conversion.
Your calibration factor may be very positive or very negative. It all depends on the setup of your individual loadcell, and the direction the sensors deflect from zero state. Need to experiment!
Hack the HX711 board to set pin 15 high, for 80 samples per second.
This example code uses bogde's excellent library: https://github.com/bogde/HX711
bogde's library is released under a GNU GENERAL PUBLIC LICENSE
Arduino pin 2 - HX711 Clock
pin 3 - Serial Data In
5V - VCC
GND - GND
Yellow LED on pin 13, igniter transistor/relay on pin 11, momentary pushbutton on pin 12.
Most any pin on the Arduino Uno will be compatible with DOUT/CLK.
The HX711 board can be powered from 2.7V to 5V so the Arduino 5V power is fine.
#include "HX711.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7);
const int buttonPin = 12; // start sequence button
const int ledPin = 13; //LED indicator and/or buzzer
const int igniterPin = 11; //igniter transistor circuit
int buttonState = 0;
#define DOUT 3
#define CLK 2
float calibration_factor = -560; //-560 works for my 10kg loadcell.
pinMode(buttonPin, INPUT);
pinMode(igniterPin, OUTPUT);
pinMode(ledPin, OUTPUT);
Serial.println("HX711 Rocket Motor Dynamometer, V.5");
Serial.println("Affix motor nozzle up. Place igniter in nozzle. Move away from test stand.");
Serial.println("Press start button to initialize ignition sequence.");
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" MODEL ROCKET");
lcd.setCursor(0,1);
lcd.print(" DYNAMOMETER");
delay(2000);
scale.set_scale();
scale.tare(); //Reset the scale to 0
long zero_factor = scale.read_average(); //Get a baseline reading
Serial.print("Zero factor: "); //This can be used to remove the need to tare the scale. Useful in permanent scale projects.
Serial.println(zero_factor);
Serial.println(" ");
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" Rocket Dyno");
lcd.setCursor(0,1);
lcd.print(" STDBY " );
scale.set_scale (calibration_factor);
lcd.print(scale.get_units(),1);
lcd.print(" g");
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" STAND CLEAR!");
Serial.println("IGNITION SEQUENCE ACTIVATED!");
for (int i=0; i <= 50; i++){
digitalWrite(ledPin, HIGH);
delay (100);
digitalWrite (ledPin,LOW);
delay (100);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(1,1);
lcd.print(" AQUIRING DATA");
digitalWrite(igniterPin, HIGH);
Serial.print("Start time, ms: ");
Serial.print (millis());
for (int i=0; i <= 800; i++){ //800 samples at 80sa/sec = 10 seconds theoretical
scale.set_scale(calibration_factor); //Adjust to the calibration factor
Serial.print(scale.get_units(), 1);
Serial.print("Stop Time, ms: ");
Serial.print(millis());
digitalWrite (igniterPin,LOW);
This code gives me a "scale was not declared in this scope" error when run.
Can anybody help me to addept the code so it will work?
Kind Regards,
Bulldog
